Thread: Bottom Drive Pullywheel Broken
    Oct 2006
    nottinghamshire
    Default Bottom Drive Pullywheel Broken
    Hi Guys Ive got a 2005 Vectra c and is under warrenty until Sept, last night while i was on my wy home the bottom drive wheel on the engine as broken off, when i pulled away from the traffic lights on a slight incline the car stalled, so i started it again and this knocking noise was heared coming from the drivers side, so i took a look but could not see anything so i continued to drive home approx 3quarts of a mile after approx half way the temp gauge started to rise above the 100 mark and engine warning light came on and the battery light. so as i was only yards away from home i continued, on inspection this morning you can see that the bottom wheel is completly broken. my main questions are
    will vx dealers pick up the car?
    and could i claim a courtesy car while works being done?
    what damage would it have done?
    I purchased this car from a garage not network q in October
    any advise would be appreciated.
    Quote Originally Posted by faz3270 View Post
    I'd certainly hope so - or depending on your type of breakdown they may relay you.
    I'd have also hoped the dealer would supply a courtesy car for the time they have repairing it.
    I'm assuming on the 2.0DTi the water pump is also driven off that Multi-V belt - along with the AC, power steering and alternator - so that would be the reason why the engine got hotter. As long as you didn't drive it for long once it got up to 100, then I wouldn't expect you've done anything.
    So it never came with a Net Q warranty? I see it's an 04 model - do you still have any Vx warranty left on it?
    Oct 2006
    nottinghamshire
    Thanx for the reply just to confirm its a 2004 2.0dti with vx warrenty until sept 07.
    Then at least there isn't that bit to worry about - should hopefully be a straightforward Vx warranty job.
    Hope you get it sorted soon.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Ouch, sounds painfull. My dad had a Mitsubishi Colt which had a recall because the bolt used to hold the bottom pulley in place was a mm or two too long & so when torqued up wasn't quite pulling tight on the pulley. From excessve vibration the bolts were working loose then falling out, off came botom pulley & bend goes the engine.
    I'm sure your warranty though should leave you with nothing to worry about.
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Same thing happened on my old 04 2.0 dti at about 60k. I keep hearing from people about this problem but is the first time ive seen it mentioned on Vectra-c. RAC recovery for me and no courtesy car. IIRC it was just over 60k so out of warranty but vauxhall agreed to pay %40 goodwill. Make sure they put ALL the screws back in the undertray, mine fell down soon after the repair and was completely trashed by the time I noticed
    Oct 2006
    nottinghamshire
    Thanx guys going to call dealers to see when they can get it fixed
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  2. Spring help top or bottom
    By vekky c in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2012, 11:45
  3. The bottom grill
    By Ginge7289 in forum Bodywork & Interior
    Last Post: 9th March 2011, 23:10
  4. Bottom spoiler bit
    By Kinjo in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2008, 08:36
  5. top spoiler with or without bottom?
    By vectragsi3.2 in forum Styling
    Last Post: 15th January 2008, 21:30
Bottom pull wheel sheered off on vectra engine
