Results 1 to 10 of 25
Thread: ParkPilot Factory Fit (Favour required)
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Default ParkPilot Factory Fit (Favour required)
    All,
    Many of you may have read that i'm attempting to fit factory rear parking sensors to my Veccy C. I'm using the Bosch/Vauxhall aftermarket kit coupled with Vauxhall factory mounting parts to hopefully get the factory look and not aftermarket look.
    I need someone with factory fit park assist (not dealer fit) to give me and exact measurement of the diameter of the hole in the rear bumper. My initial thoughts are that the diameter is 29mm, can someone please check and confirm this for me.
    Much appreciated as always,
    Paul.
    aarrgghhh!!!!..
    i just had the rear bumper off the signum yesterday.......i could have measured it then..
    one thing i did note is that VX plastic weld some extra 'stiffners' or packing around the holes so the actual sensor sits in twice the bumperskin thickness of packing....so without it they may be loose..
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Is the circle inprint on the back not the size of hole which needs to be cut out. I recall mine had a + in the middle of the circle to indicate the central point & for some reason the circle was centrally located in the middle of a square.
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    the holes on bumpers that are factory are tapered so the sensor sits on a
    lip when you push them in.
    there shud also be the + to show were the position the sensors should be
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    [Ex]Admin Duncan's Avatar
    That'll be the 'shoulders' we've spoken about Paul - the ones that come on the different bumper if you get factory fit.
    As Ben said, isn't the size of the hole indicated on the back of the bumper?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    As Andy says there are some + marks to show where to drill..
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    i know on my vectra (preface lift) it had the circles already marked on the inside of the bumper but when i did the in-laws (postface lift) it didnt.
    Ah, that must be why Paul is asking then as he has a facelift. You'd have thought they could have left those on!
    Jan 2006
    Crewe
    yeah you would, i thought ah this will be easy and only take a few minutes! but noooooo out came the ruler and laser level.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    This throws a spanner in the works then, I looked at my mates Siggy facelift yesterday whic has factory sensors. His sensor is identical to the one I have got with the VX aftermarket kit.
    All I wanted was confirmation from the outside that the hole in the bumpers is 29mm which i'm 99% sure it is.
    Looking at my mates Siggy his holes are actually straight drilled and not tapered. There is a plastic rectangular sensor holder that glues to the rear of the bumper and this froms the tapered ring around the sensor when pushed in to the hole from the rear.
    When I fitted the aftermarket kit to my pre-facelift Vec the locations where to drill where marked with a circle and cross so you made sure you were on centre. I also recall that surrounding these drill templates there was a rectangular template, this is where the plastic sensor holder glued to the bumper sits. On the front of it is the built in sealing ring that gives the recessed look from the outside.
    Are we deffo saying that there are no drill templates on the facelifts? Makes the job alot harder!
  1. a favour required
    By farley2708 in forum General Chat
    Last Post: 5th July 2012, 22:52
  2. parkpilot
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 00:40
  3. A wee favour required.....
    By Mikey4996 in forum General Motoring Chat
    Last Post: 1st December 2011, 20:58
  4. Parkpilot
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 11:18
  5. Factory fit parkpilot kit. complete Fitting instructions
    By Big-Pete in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2007, 12:40
