Thread: Buckled wheel
    Regular Member steve.o's Avatar
    Jun 2006
    walking in memphis
    Default Buckled wheel
    Well after posting about my new wheel probs last night,"wheel vibration" i took them to be re-balanced today.The guy who re- balanced them said that there was'nt much in it,especially to cause the type of vibration that i said i was getting.He started working on the last rear wheel and noticed that it was'nt fitting flush to the hub After further inspection he seemed to think that the wheel had not been properly "jigged" at the factory where it was made and that it looked buckled and has advised me to contact the company that i bought it from and ask for a replacement So after all that re-balancing the car is still vibrating like a goodun and i am majorly p****D off Only thing is would the rear wheel make the steering wheel vibrate like it does,as if still not balanced properly? All advise very welcome.
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    apparently if its one of the rear wheels you'd feel it through the car seat and not the steering wheel
    Jun 2006
    walking in memphis
    Yeah,thats what i thought.Still going to give them a ring on monday and get replacement.And it looks as if the balancing "STILL" is'nt right.
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    i've recently had nightmares with my 19's and balancing.. almost was ready to throw them away and get a new set.... Found a good refurb, new tyres and then balancing and the wobble is now all sweet
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Slightly off topic,have your tyres got any coloured dots on the sidewall?,if so they can indicate a 'light' point in the tyre,the dot should be aligned to the valve to make balancing easier.
    [Ex]Admin Duncan's Avatar
    And further info on that here - scroll down to "Coloured dots and stripes - what's that all about?"
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    tyre make / quality might also be an issue here, cheap tyres are a nightmare at times, and as already said spiggot rings too....
    Midlands Mod Shop - NFFC.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I 'borrowed' the info from here as balancing isn't a big thing on buses!,but the post did put a dim light on in my brain.
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    I had a badly buckled front wheel. When the wheel was on the front, once i hit around 60-65 mph the steering wheel vibrated wildly. I didnt know that it was the buckle causing this until i went to get 2 new front tyres, and when the guy was balancing them we could clearly see the buckle. It wasn't that the balancing was just picking it up, it was plain to see, it was that bad!!! He then swapped my front wheel with one from the back and when i drove away it was like driving a new car. As a result i concluded that the buckle had to have been affecting the steering even at low speeds, and when i got the veccy on the motorway i couldn't even feel the buckled wheel once it had been moved to the rear. I have since had it fixed as a buckle leads to un-even tyre wear (and the thought of it being buckled would do my head in) however i was informed to always keep it on the back!!!
  1. Buckled xp2 wheels
    By sla002 in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2012, 18:37
  2. buckled wheel repair,how successful?
    By pogo in forum Vectra C / Signum Troubleshooting
    Last Post: 17th August 2012, 23:08
  3. Buckled Wheel Dilema
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2012, 15:32
  4. buckled wheel
    By honyin in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2010, 22:31
  5. Buckled Wheel
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 16:55
vectra rear buckled wheel
