Qx triple alloy wheel cleaner , did no spray them as just a quick refurb as be back on road Monday.
This is a side view of the refurbed front and rear original waiting to be refurbed , I thought they looked grey at first but may have been the low light .
Actually look pretty much stock , which I thought looks great .
Nice work.... Need to get mine done!
Nice job there Paul, and pretty fast work as well. Gonna have to put up some full pics of the car when you get the rears done.
Cheers Kev . yeah rubbed down with 120 grit then used aluminium filler , 400 grit, primer 2000 grit, base coat , degrease then lacquer, got the third one primered tonight .Ready for basecoat .
So should have them done fully tomorrow , masking is a ball ache but then spraying take minutes .
Full pics tomorrow buddy.
I popped wheel nut covers oto my locking nuts by buying some 19mm(?) ones (it was 2mm bigger than the standard vextra ones). Just finishes it off nicely.
today I resprayed the really bad rear o/s alloy , this had a chunk taken out near one of the dimples making a difficult job , anyway heres pics of the rear o/s amd n/s which is drying overnight before final lacquering .
£8.99 ebay 5 litre have been using this a lot it's good stuff for the price .
120 grit wet and dry and old paintbrush then wash it off.
then turned it over did same and let the pressure down
damaged section and also here as well
after the o/s wheel had dried from the primer stage it had to be refilled as it was showing a little bit from where the chunk had been taken out , so now it was time to kill 2 birds at the same time and prep the n/s and refill the o/s rear .
O/s rear
and filed and sanded both .
here is the now repaired n/s rear ready for primer.
o/s rear now primered
then base coated.
and reinflated and refitted.
and the now repaired rear n/s alloy .
and then primered
tomorrow finish the n/s rear needs lacquer .
Here is the filler I used loads left £8.99 ebay.
and 16 new bolts which Wheelbase gave me by mistake when I bought the 17" alloys for the Sierra , fords use nuts and Vauxhall use bolts had them in a bag since 2003 .
repaired area now good as new
just base coated
here is the O/S now finished
Finished photos , all 4 done and refitted , wash down and tyre dressing tomorrow.
And before
Nice job! Come and do mine!
Paul
Stunning diy job on the alloys, I would wait and let the paint settle for a week or two though before dressing the tyre's depending whats being used.
