Thanks Thanks:  1
View Poll Results: Have you had any warranty work done on your car....
Voters
381. You may not vote on this poll
  • Yes - Fixed without any hassle.
    185 48.56%
  • Yes - Fixed after a lot of visits/pressure
    102 26.77%
  • No - It goes like a dream (Touch Wood)
    94 24.67%
Page 7 of 7 FirstFirst ... 567
Results 61 to 63 of 63
Thread: Common Faults.....
  1. #61
    Regular Member richardcee's Avatar
    Feb 2012
    Falkirk
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.9 CDTI 16v Turbo
    Year : 57
    Mileage : 69473
    Hey anyone no the cause to why my display pannel thats display the time always tells me ive got bulbs out out when ive not ive checked all my bulbs all bulbs are working fine
    Many thanks
    Sent from my SM-G930F using Tapatalk
  2. #62
    Feb 2018
    GB
    Vehicle : Vauxhall Signum
    Engine : 2.8 V6 Turbo
    Bad connection to the light cluster? Or if you're using LED/HID bulbs they will show faults.
    Sent from my CLT-L29 using Tapatalk
  3. #63
    Nov 2013
    suffolk
    Vehicle : vectra 2007
    Trim : sri
    Engine : z18xer
    My old Vectra 1.8 VVT 2007, has had quite a few Cooling system faults over the years, judging by the Parts readily available on Ebay, I think most are probably "Stock faults" Here is my list, feel free to add yours:
    1. Thermostat, & as the plastic housing cracked when removing old Stat, that was replaced as well.
    2. The Brass temperature sensor that is located at the rear of the Stat housing. They can go open circuit intermittently, or slowly change value. A key component, that tells the CPU what the temperature is, or it THINKS it is!
    3. The oil cooler replaced.
    4. Water pump.
    5. Radiator, they leak from the plastic part, on the air cleaner side.
    6. Expansion plastic tank & cap - the level switch failed, & the tanks can also crack.
    7. The Thermostat to throttle body pipe, they go brittle with age - the part that connects to the thermostat disintegrated! Does the same happen to the other similar pipe, that goes from throttle body to the Expansion tank?
    Surprisingly, the coolant hoses seem to last very well.
    Any more?
  1. What are common faults on a 2.2 SRi Direct Automatic....
    By Vectra Adz in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2012, 21:26
  2. Signum 2.8T common faults?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 14:24
  3. Common faults
    By welshboy in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 22:56
  4. Common Faults 1.9 CDTi (150)
    By Chappers. in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 21:56
  5. 2.0 DTI Common Faults?
    By antowns in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 09:10
common problems of Opel Vectra
vectra problems
vauxhall vectra c common faultsVauxhall Vectra 2007 common faultsvectra c problems2008 opel vectra common faultsvauxhall vectra c issuesVauxhall Vectra Problems
