Thanks Thanks:  1
View Poll Results: Have you had any warranty work done on your car....
Voters
382. You may not vote on this poll
  • Yes - Fixed without any hassle.
    185 48.43%
  • Yes - Fixed after a lot of visits/pressure
    103 26.96%
  • No - It goes like a dream (Touch Wood)
    94 24.61%
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 63
Thread: Common Faults.....
  1. #41
    yes, the faults carry over as the signum is based on the vectra estate floorpan..But don't panic..most cars suffer no, or just minor faults..
  2. #42
    May 2008
    St.Albans
    Good thread
  3. #43
    May 2008
    Alloa (scotland)
    Cheers mate . was wondering what to look for before the warranty runs out next year .
    Thanks again
  4. #44
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    The only fault i have had with mine is the little barstewards who have put a deep scratch on thr rear door & quater panel
  5. #45
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Had a CD30 HU replaced under warranty because of a sticking bass button.
    The only problem the garage had was deciding whether or not to do it under the Network Q warranty or the Year 2/3 warranty.
    Apart from that the 1.8i Life is a dream. No EML Lights or spanners etc (touch wood)
  6. #46
    costa rica
    confused Chevy Vectra with transmission problem
    My 2003 2.2 Vectra is having transmission problems, transmission gets stuck in 5th and 2nd ( auto/shiftronic). Mechanic says it is the transmission speed sensor. Anyone knows about this issue.
  7. #47
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Your mechanic might be right (or wrong). Your transmission has basically done this http://www.vauxhall.co.uk/vaux/stati...a_OM_Feb07.pdf pages 188 and 189 of the manual but I can't help with the solution - sorry.
  8. #48
    Aug 2009
    Suffolk
    Good thread.
    Poor cars lol
  9. #49
    Nov 2009
    hemel hempstead
    my 2006 1.9cdti had a rough running fault when i bought it and the car with a spanner in warning light was constatly on with ignition(cheap due to fault) tech 2 wouldnt pick up a fault code but there was one in there.. turbo boost presure loss.
    turns out to be a small pin hole in one of the rubber pipes...
    soaked them with soapy water and found bubbles.. car runs like a dream and i took it back and showed the dealer.... his face was a picture. i think he lost money on that because i paid cash too.
  10. #50
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I've recently acquired an 08 Vectra C, 1.9 CDTi 150 (auto) so hopefully I'll escape some of this. I did notice dip wasn't great, wondered if it was my tired old eyes, replaced bulbs with xenon upgrade and fine now.
    Unfortunately as I have mobility issues I do do a lot of short journeys, balanced by a long run around once a month. Not sure that'll be enough to keep the DPR happy, time will tell.
    Will watch/listen out for some of the other faults, just in case!
  1. What are common faults on a 2.2 SRi Direct Automatic....
    By Vectra Adz in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2012, 21:26
  2. Signum 2.8T common faults?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 14:24
  3. Common faults
    By welshboy in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 22:56
  4. Common Faults 1.9 CDTi (150)
    By Chappers. in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 21:56
  5. 2.0 DTI Common Faults?
    By antowns in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 09:10
common problems of Opel Vectra
https:www.vectra-c.comforumshowthread.php211-Common-Faults
vectra problems
vauxhall vectra c common faultsVauxhall Vectra Problemsvauxhall vectra c issues2008 opel vectra common faultsvectra c problemsVauxhall Vectra 2007 common faultshttps:www.vectra-c.comforumshowthread.php211-Common-Faults#::text=Radiator mounts worn or Front Fix.&text=Knocking from rear of car.&text=Shock absorber leaking.
