Thread: swirl valve ?
    Mar 2007
    london
    Default swirl valve ?
    Hi,
    I,ve a lot of problems with smoke on a warm start up over the last 6 months. It's 150 CDTI, 04 plate. The dealer is running out of ideas and most parts have been replaced. I was looking at the swirl valve control rod next to the glow plugs tonight and noticed they were quite loose. I thought i could see something coming out from under the black part that mates with the inlet manifold. Whilst the car was sightly warm i got a jug of water and poured slowly over the all of them. The water disapeared and steam started to come out of the exhaust and the engine started to run roughly.
    This points out to me there is a seal problem or leak there.
    Should there be a leak there or should they be air tight??????
    many thanks,, hope someone can help....
    Regular Member benny's Avatar
    Feb 2006
    dudley
    air tight all day long mate if you have a air leak it will make it black smoke ...
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    Ah, i'm glad u mention that. ever since they 'recalibrated' my swirl valve with a software update its been kicking out a lot more smoke on full throttle
    Mar 2007
    london
    it only smokes after i have left the car for 2 hours and then its white diesel smoke. It sounds like there is extra unmetered air getting in past these swirl valves... ??
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    the resident Gsi3.2 will probably have some valued info upon his return from having his wallet lightened... should be around on the forum soon
    Quote Originally Posted by keith101 View Post
    White smoke is unburnt diesel..unmistakeable..it's not a problem with air, it's a problem with too much fuel..so start thinking along the lines over overfuelling/leaking injector or if it clears after a short period, it may need to see a dealer to see if it's overfuelling on the 'coldstart' cycle..
    Black smoke- rich mixture- not enough air
    Blue smoke - oil - breathers or rings
    white smoke - unburnt diesel
    Quote Originally Posted by plasma View Post
    :..accountants.. painful things..
    Mar 2007
    london
    Just had the injectors replaced, second time ! it only smokes after the engine has warmed up and then been left to cool down for a couple of hours.. If the engine has to pre heat it does not smoke, on a cold start no smoke. It's had the EGR fix done on it but still smokes AAHHHHHH !!! I can replicate it by taking the solinoid off the EGR and depressing the EGR valve a little myselve, But i dont really want to be telling the dealers this ! It's had so many parts replaced now i lost count.....
    Help !!
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
