Results 1 to 3 of 3
Thread: Vectra C Koni Springs
    Regular Member Pronto13B's Avatar
    Feb 2007
    Ripon
    Default Vectra C Koni Springs
    Guys apparently these are a set of Koni springs, this is the info and a pic, can one of you guys confirm for me?
    Vectra C 4 cylinder part number 1020-6102
    Vectra C Saloon 4-cyl, front axle load up to 1000kg 4/02> Lowers 30mm
    [Ex]Admin Duncan's Avatar
    If these are for your car, you'll want the next set up I think. Your front axle weight will be 1060kg if it's the same as the Signum with that engine (which I think it is). Check on the plate on the drivers side B pillar.
    Feb 2007
    Ripon
    Not for mine mate.. lad got sent these for his.....by mistake and he needed for the B so he has been told he can keep em and they will send a new set out.. just wanna make sure they are for the C
  1. Koni FSD + H&R springs
    By BYGino in forum Handling & Braking
    Last Post: 11th September 2012, 20:17
  2. Koni springs???
    By zazaszazas in forum Handling & Braking
    Last Post: 29th March 2009, 00:54
  3. Koni FSD shocks & springs
    By Matt21385 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2008, 17:45
  4. Koni FSD & H&R Springs
    By mark1319 in forum Handling & Braking
    Last Post: 27th November 2007, 19:39
  5. Koni Springs On Ebay
    By topline in forum General Chat
    Last Post: 1st July 2006, 23:47
koni to vactra c
what is the best axle load for a vectra c
vectra c front axle weight
