Results 1 to 10 of 11
Thread: "can Anybody Help "
    LONDON
    Default "can Anybody Help "
    Hi
    Guy's could anybody help, have been told my auto/gearbox
    on my 2.2 elegance is shot ! quoted £1700 recon fitted ,
    but wondering if a vec b auto box could be fitted ?
    Different box i'm afraid...the vectra C has more 'gears' in it, as i recall my vectra B only had a 4 speed box..
    Has it gone because of water getting in the box? or has it just burnt out?..
    if it's water, then you could try just changing the radiator and flushing the box through with several full changes of ATF transmission fluid.. that may cure it for you, it all depends on how long the box was 'wrong' for...if it was only contaminated for a very short time you may well save it.
    If it was water, as well, make sure they do change the engine rad as that'll be where it came in from..
    If it's just burnt out, then you'll need another box, or get the existing one rebuilt..Have you tried E-bay for another vectra-c box??.. they are out there.. or a specialist vauxhall dismantlers?..
    LONDON
    Thanks ! "wish it was just water" ... def burnt out !
    like the sound of rebuilding existing box though , hopefully might end up a cheaper option thanks for the advice !
    try searching in the yellow pages under ' automatic gearbox specialists'.. they will list all the local one's to you..
    I'm about 40 miles out of london, so my local one prob won't be any use to you....
    LONDON
    Thanks,
    dont know if i could arrange something with your motor/works
    i do shift work week on week off depending how long it would be there
    i maybe could pull it off , how long do you think it could be ?
    it could be about a week, and they do bookings..
    Their number is 01525 385159.. ask them for a quote, and see what they see..
    they did a cracking job on a mondeo box for me..
    Nicking Ya Dinner.
    Don't rebuild it, it will be broken again in a short period, recon or a second hand one is the way to go, if it's second hand ideally try to see it in the donor car 1st, as it gives you an idea of it's condition, anything over 60k avoid unless you are gonna shift the car soon afterwards.
    LONDON
    Hi Guy's , sorry for the delay just geating my bearings after nights !
    thanks for the advice, gives me some more options to think about !
    been a bit unlucky with this veccy only had since aug 06 got bumped in the back 1 week after purchace , got repaired , then got side wiped in dec ! , 2weeks ater getting her back , followed by a new battery ,to be told by the aa guy my cat has just about gone , which as of yesterday
    ems light on and looks like my lambda gone ! fuel consumtion hit'n the roof ! ontop of the box ! so got a lot to think about !
    It's a shame coz i do like the motor ! thaks again for your advice !
    Dec 2005
    In the sponge-monkey tent
    Crikey, you're not having a lot of luck, it's not Prestige Blue is it?
    Regular Member j13hdb's Avatar
    Nottingham
    01159244600 Vauxhall breaker in Nottingham. Never been just saw his van the other day and took his number! Might be worth a try if all else fails
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  3. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  4. "Goodbye" grey sky, "hello" blue !
    Last Post: 24th October 2008, 12:34
  5. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
