Thread: Engine Loosening up?
    Regular Member denzo's Avatar
    Runcorn
    Default Engine Loosening up?
    Can someone please explain what Engine 'Loosening' actually means? what really happens, how can you tell it has happened?
    Regular Member Harry's Avatar
    Uxbridge, London
    i may be wrong here but is this similar to the engine having been "run in", but only over a longer period than 500 odd miles which i think is the recommended time to drive the car conservatively.
    i imagine its when all the parts have bedded in.
    i'll probably be corrected soon enough so you may not want to pay much attention to this post!
    York
    had a cav v6 rebuilt and i took 500 miles to run it in or "loosen up". There is a massive difference to how the engine "feels" when driving it. To start with the engine didnt't seem to be happy to rev freely, but this steadily got better as miles came on i.e. looser. as posted above all the machined parts are never perfect an so need to safely rub against each other to form the same shape i.e. crank against bearings, piston rings against bores etc. after an oil change and another 500 miles and another oil change the engine can be "thrashed" without fear of it breaking. This should be done in the factory for a new car, so as far as loosening up is concerned for a new car you wont really feel a great deal, but after say 10,000 miles it will be easier and revvier to drive, but you may not notice. Also, the worst way to run an engine in is constant revs, say on a motorway. the best - town driving going up and down the rev range. hope this helps
    Uxbridge, London
    hmmm...i've always thought that motorway miles are the "healthiest" miles a car could do??
    Quote Originally Posted by denzo
    When it falls out onto the road!!!
    On a serious note, polisher has really answered the question. It's when engine parts have settled in and run smoothly against each other.
    York
    Thumbs up
    hi guys, just to clarify my previous post
    motorway miles are great for a car thats been run in as the constant speed minimises wear, but to loosen an engine, it needs to wear to smooth the bits and peices together.
    hope i've clarified a little
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Replies: 35
    Last Post: 5th May 2012, 15:32
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
