Thread: water in footwell
    Feb 2007
    airdrie
    Default water in footwell
    guy i k sort of now on another forum has a 3 yr old signum and the passenger footwell is sponging with water, hes checked the doors and windows which are fine, anyone got any ideas ?
    thanks in advance
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    Quote Originally Posted by silky View Post
    thanks in advance
    1) Front windscreen seal - but they're bonded, so highly unlikely
    2) Heater matrix / air con matrix is leaking - but is the coolant level low?
    3) Rear Hatch seal is knackered - you'd be surprised where water ingress ends up
    4) Air intake to passenger compartment is bunged up with leaves & crud, meaning water is collecting in the bulkhead area & leaking in eventually.
    I assume the car hasn't been in the bodyshop & they've forgotten to put a grommet back or something?
    Hope all this is of some hope.
    Feb 2007
    airdrie
    read somewhere about the oil cooler leaking, is that a possibility???
    Hertfordshire
    Do you mean the air con matrix? They're supposed to drip a little (humidity etc) but there's a run off pipe to under the car somewhere - not enough to cause a flood in the footwell.
    Check that boot seal - or the rear doors.
    Here, there and every where!
    Also check the drain tube under the pollen filter.
    Door seal is a common fault too.
    Regular Member robzc's Avatar
    Mar 2007
    South West
    Had this prob with a Ford Fiesta, the pipe for the aircon condensate drain became blocked every 6 months or so & I had to climb under the car to open it up but aircons shouldn't really be in use this time of year, so it's unlikely.
    Hertfordshire
    Quote Originally Posted by Caterman View Post
    That's the bit I meant above - you take out the glovebox & there it is behind a black cover. Just slides out. It stops pollen, leaves, mud... everything!!!
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I had same thing with my Edition 100 2.0T when I bought it 18 months ago on Network Q. Problem caused by the drip tray under the plastic area at the bottom of the windscreen - only has a few small holes for water to drain away. Mine had become blocked or debris (leaves,bits of twig etc.) had accumulated underneath meaning that water ended up in the passenger footwell , perishing a grommet on the way.
    Seems that the Network Q 114-point check is a load of cobblers cos they missed it, but sorted OK under Network Q warranty. I was told it was well 'bunged up' . I believe the first owner couldn't be ar$ed to check, as it's a common potential problem area. I park under trees (no choice) but at least it's in a driveway, and I monitor it closely, and have not had a problem since. Hope this helps.
    P.S. Wonder why VX stopped using the 'lattice' effect above the drip tray (hope I'm describing this right),with lots of room for the water to drain away, as seen on the old Astras.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Paddy2bsure View Post
    That's where I would check first. Haven't had the problem, but it seems to have been the cause of water in the footwell for a number of people.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Also try this grommet. It was the cause of water in my car. Just under right hand side of scuttle.
  1. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  2. water in footwell
    By jsnlvxr in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2012, 12:54
  3. water in footwell
    By vectra craig in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2010, 20:57
  4. Water in osr footwell
    By T555DAN in forum Bodywork & Interior
    Last Post: 20th September 2009, 21:17
  5. Water in my footwell !!!
    By Rocky Balboa in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 12:20
