Results 1 to 10 of 25
Thread: little advice if you can
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default little advice if you can
    hi
    i just got my vectra its a 1.9 cdti sxi on a 2004 plate and its covered 70k
    all seems well but when it starts up first thing
    it sounds like its struggling but it does start
    after about 20 seconds it seems fine
    i know its like a shot in the dark i know but what do people it it could be ?
    would a cleaer in the tank maybe help like redex ect (or any recomend ones)
    also is the 1.9 cdti belt or chain drien? and when is the best time to change them
    thanks
    baz
    Regular Member robzc's Avatar
    Mar 2007
    South West
    I personally wouldn't put any additives in the tank at all, I know they can help sometimes with petrol motors, but I'd really not like to drop anything into my CDTi's tank.
    My car has 80,000 on the clock and starts and runs fine, but do you allow a couple of seconds for the glow plug warning light to go off before you start the motor, especially when cold?
    Mar 2007
    swindon
    Quote Originally Posted by robzc View Post
    thanks for the advice staying cear of additives i will knock that idea on the head
    i always allow for light to go out first so that should not be the problem
    i have just come for a 2.0 hdi 306 and that was sweet on start up
    any other ideas what it might be as im not sure
    Mar 2007
    South West
    Not sure mate, my car sometimes even fails to start if I don't wait for the light, but if I do it starts sweetly & runs fine straight away.
    If you just bump this thread up the list later tonight, there are stacks of blokes who know the veccy's much better than I do that will have some advice.
    Sorry mate, are you saying it struggles to start or, once started it struggles to run?
    Is there much smoke from the exhaust on start up?
    Mar 2007
    swindon
    once its started its fine and runs fine
    its just the first few seconds as you turn the key when you start her up its sound rough and chuggy (not the easiest thing to explain)
    not sure on the some will have a look tomorrow morning as we are due a nice frost tonight
    and all your fluids (oil, water etc) are OK?
    If they are OK, I would say there's nothing to worry about. I'll have a close listen to mine in the morning.
    Mar 2007
    swindon
    all levels are spot on
    it might be just me as its new but it just dont sound 100% right
    i might try leaving it an extra 1 min after the light is off just to see what happens
    Baz
    Regular Member DesignforLife's Avatar
    Lancashire
    Thumbs up
    Hi Baz,
    I might be wrong here: But as yours is a CDTi - it is 'direct' diesel common rail - you shouldnt have to wait for a glow plug - it should fire up straight away.....
    The symptoms you describe sound like overfuellling or lack of Air on starting. Chuggy rough running normally happens when the engine has a tuning box and the colder ambient temps cause too much fuel to reach the engine.
    Does the engine clear after a gentle rev? Check the Air filter - for dirt and or blockages.
    As for using additives - I swear along with others on here that using them is a requirement. A friend who has 30 plus years in Diesel marine trade always tells me to treat the fuel every other fill up and every 10K put a injector cleaner in with the fuel. Just my opinion - not gospel.
    Cheers - Matt
    Mar 2007
    swindon
    Quote Originally Posted by DesignforLife View Post
    Hi Baz,
    Cheers - Matt
    hi matt
    thanks for the tips
    yes after a gental rev its fine so i will have a peep in the airbox see if it full of ****e is it worth me changing it to a K AND N filter?
    as far as im aware its never have a tuning box on
    as for additives/ injector cleaner what do people recomend , i will do my homework and decide if to use it or not
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
