Hi guys
Any idea what would cause a CDTI 150 estate to stall out randomly? (my dads car....tempremental thing...)
Happens at seemingly random intervals, in town, on the motorway etc/ Won't bump start (i.e. dropping the clutch) but will start up no problem if you turn key off and back to start.
Throws P2150 and P2147 errors, with occassional P0268 error
At times also flashes up water in fuel errors on screen but doesn't log a code...
Had previous DPF errors(wouldn't rev out, sensor errors) some severe italian tuning seemed to have sorted that, EGR and MAP sensor both thoroughly cleaned recently. Possible DPF involvement?
Has been done thus far:
all injector wiring plugs replaced
Spill off pipes between injectors replaced
Diesel filter replaced
Battery left disconnected for a while (the old turn it off and back on theory)
Any ideas what to look at next?
Had an ECM software upgrade a few weeks back to improve the DPF regens, dealership botch the update perhaps?
Any help GREATLY appreciated before I lose my mind completely.....
