Thread: 120 vs 150
    Default 120 vs 150
    I know the 150 cdti is faster, more torquey etc, but is the 120 more reliable with regards to swirl valves, turbos, pumps and injectors, and has any member had probs with the 120, (gearbox and DMF for instance) Thanks.
    Feb 2007
    Telford
    I dunno. I've only had the 150 cdti for a few months but it still manages to scare the pants off me when the turbo kicks in. Much more grunt than the old 2.0 petrol Vectra B I got rid of.
    DenisCB
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    had a 120 for 4months now and no probs here (touch wood) so far
    Midlands Mod Shop - NFFC.
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Had my 120 for a full year now, 27k on the clock and no problems.
    Regular Member silverhairedracer's Avatar
    ESSEX
    18k on the clock,with no problems..........so far .............touch wood.
    Leicester
    the 120 and 150 are just as good as each other. What you have to bare in mind, the stories of DMF's and swirl valves etc do appear to be common on here, but we are a small community who discuss such things.
    There are thousands of these cars out there which have no problems.
    The DMF will never fail, they can sometimes get a bit notchy which most people would not even notice, I only had mine changed as I am a fussy ****** and I had it from new so could tell it was not 100% right.
    If you buy second hand, you would probably not even notice if the DMF was as fault if at all.
    Regular Member andy d's Avatar
    Feb 2006
    Inverkip
    Quote Originally Posted by Matt View Post
    I don't know what a DMF is, therefore mine must be okay. My car runs as sweet as a nut and there is no way a couple of cars that have been with faults would have put me of buying a 150cdti
    Regular Member Higgins's Avatar
    Dec 2005
    Aylesbury
    Yeah ill second that ,what is a dmf and whats the symptoms when it goes wrong??
    Here, there and every where!
    DMF= Dual Mass Flywheel. Causes vibration when taking up the drive i think. Not had the problem myself so over to the ones that have
    Calling Plasma....and Martyn21 and rob woodhouse... tell us about your DMF probs guys, what where your sypmtoms....
