I take it that is springs only Silver V, but is that £160 including P&P. If it is then that's not a bad price at all!
Springs turned up yet H?
mm i was going to get some eibach springs for my car but after all these problems that have been flagged up i might not bother what other springs has anyone tried (successfully) that is?
The Axle weight is only a guide as the cars vary from the view of tyres and wheels you have fitted , if aircon is fitted which brake spec, thats why its difficult to get the ride height just right on the car.
the axle weights can be wrong on the car regarding spec match.
police cars have high axle weight loadings but yet standard equipment is low.
The spring rates are only slightly increased or decreased depending on engine spec
unless you get offroad spec there shouldnt be much ride height difference.
the biggest variation is between deisel and petrol.
but also if dampers are tired its easy to get soft compression control.but this is usually like driving a car made of jelly.
