Thread: Some help please guys.
    Regular Member Sway's Avatar
    Nov 2012
    Bedfordshire
    Default Some help please guys.
    Hi guys,
    I brought an insignia cdti sri navi today, the car has no power at all were the turbo would kick in, very very slow pick up.
    Checked it over with my obd scanner but no faults.
    Does it sound like a total turbo fail? Or has anyone had a similar issue? Rest of the car is totally fine no issues.
    Thanks in advance guys.
    Now in Girvan Scotland
    Sounds like a fault I still have whereas when the car is cold its ok, but when warm it shuts the turbo down, I had a local chap look at mine sometime ago and it was diag as the swirl valves, 2K miles and £700 later its doing it again, I dont think the mech cleaned the EGR valve after the new swirls were fitted and its clogged them up again, try unplugging the MAF sensor from the airbox connection (the plug nearest the airbox) like I did and it runs fine (with the fault light now on of course), next thing Im going to try is a new EGR valve and cooler as its due for MOT early August, plus some fuel / EGR / cleaner.
    Let us know how you get on ?
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Sounds like nothing more than a burst boost hose at the moment or an intercooler pipe come off. Give all the pipes a going over, it should be fairly obvious if you have such a degree of power failure but it can be amazing how small a hole/rip/tear needs to be to cause drastic power loss.
    Nov 2012
    Bedfordshire
    Had it in to my local garage, changed the maf sensor, boost sensor and dpf sensor..... but the dpf is the cause... so going to get it cut out an mapped out
    Jun 2019
    Philadelphia
    Vehicle : Lada
    Trim : XLE
    Engine : Godot 3.0
    I've had this happen to me once when I was in another state in a complete different town. Quite far from home I was. May not be much but it sure as heck helped me to rent another car for the day while mine was being repaired. I contacted a rental company and I was lucky enough to get a bonus, got the car for a cheaper price for the day.
  1. hi guys
    By 06sri in forum Introduce yourself.
    Last Post: 19th June 2012, 01:24
  2. Hi Guys
    By jimmi in forum Introduce yourself.
    Last Post: 19th February 2011, 21:43
  3. Hi Guys
    By bigtime5001 in forum Introduce yourself.
    Last Post: 6th July 2009, 18:42
  4. Hi guys little help
    By mattolly86 in forum The 'Off Topic' room
    Last Post: 23rd February 2009, 00:01
  5. What do you guys think???
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 23:18
