Results 1 to 10 of 14
Thread: Any Autoelectricians Here?
    Regular Member vectrahuw's Avatar
    Feb 2007
    Wales
    confused Any Autoelectricians Here?
    im having trouble fitting an aftermarket headunit.
    ive bought the vx fascia kit and have a brand new blaupunkt memphis mp66 headunit.
    ive wired the wiring adaptor up correctly and checked all fuses.
    But, the blaupunkt wont power up?
    But, when i plug the original vx unit into the wiring adaptor it works!
    Ive also tried my m8's aftermarket headunit in my car, but no power to that either??
    Strange....HELP!!!
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Question
    Have you def got an ignition feed to it (red wire to new stereo)? As a lot of newer vectra's dont have one due to stereo operating off can bus signals!
    Feb 2007
    Wales
    yeah def. i had to plug the red and yellow wires into the block connector that goes into the new headunit.
    it must bo right cuz the vx headunit works when its plugged into it.
    Jul 2006
    Colchester
    Yeah but the VX headunit wouldnt need a Ignition to it.
    Basically all you need is a perm 12v on the yellow, ign on the red and the earth on the black. Just those should make the unit power up.
    Feb 2007
    Wales
    ive looked at the blaupunkt headunit booklet and plugged the yellow into the correct block number.
    yellow is for power (even thought the little sticker on it says 'ignition')
    correct?
    Jul 2006
    Colchester
    Blaupunkt may be different but 99% of stereos have perm live on the yellow. A bit irrelivant at this stage coz as long as you have live on the 2 it should power up. Have you tried powering the unit off the battery with a few odd bits of wire just to see if it lights up, just in case its faulty?
    Feb 2007
    Wales
    i will try this asap.
    so if i just stick one end of wire on the + of the bat and the other on the correct pin on the headunit it should power up yeah?
    (sorry if i sound thick)
    i just dont wanna blow anything!!
    if it duz power up this way....
    ...what duz this mean!!??
    ive dun sumthing wrong with the block connectors?
    Jul 2006
    Colchester
    Possible something wrong. What year Veccy do you have?
    Feb 2007
    Wales
    2002 sri 1.8
    Regular Member Ben H's Avatar
    Herts\Beds Border
    2002 SRi should be on ISO, my one is & it does have an ignition live to the radio. Should just be a plug in job.
