Results 1 to 10 of 16
Thread: 3.0cdti question
    Default 3.0cdti question
    Has anyone noticed then when the engine is cold the turbo does not spin up until later in the rev range? I have only noticed it a few times on mine and always on cold. Instead of spooling up at 1500rpm ish it doesn't until about 2500rpmish..... Anyone else had this or is it right as its a cold engine?
    Belfast
    Most likely part of the warmup cycle. My DTi is the same, doesn't boost much until it's warm, and sounds really loud and knocky.
    The cold idle revs should be slighty higher, so the activation for the turbo is obviously going to be slightly higher
    From memory, the cold idle revs is 950 rpm, but once warm this drops to about 700rpm
    The turbo activation on cold is probably therefore within the same tolerance ratio
    I thought that but its much higher in the rev range, not just a couple of hundred rpm. But only from cold, first thing or if its been sat a while..... I'll just have to see what happens and how it develops I guess.
    Today is an ideal test for this, as it is snowing very heavily, so I will compare idle revs cold and hot, and turbo activation revs cold and hold, and then reply later this afternoon
    Cool many thanks! (Its sunny here )
    Air Temperature 3'C
    Cold idle speed was about 900 rpm
    Went for some short drives on a local long straight road, NSL
    The turbo could clearly be heard kicking in at just over 2000 rpm
    I then allowed the engine to warm to 87'C, normal running temperature, then returned to the same road and repeated the test
    Hot idle speed was about 750 rpm
    To be quite honest, I don't think it made any difference whether it was cold or hot
    What I did notice was the overboost range was different
    The overboost was kicking in at about 5500 rpm on cold, and about 4000 rpm on hot
    I wonder if this is the start of yet another problem for my car
    Belfast
    Surely that's a typo?
    No, not a typo
    The turbo kicks in at 2000rpm
    As you lift the revs, in the same gear, you can feel the overboost which surges a further 20 to 30bhp
    It does seem to vary depending on engine temperature, probably not to stress the engine whilst still cold
    The overboost doesn't kick in until higher revs, as the turbo has lost most of its power by this point
  1. 3.0cdti - anything I should look out for?
    By renodci in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2012, 13:09
  2. 3,0CDTi SCV! Do I need to say more?
    By Eirik in forum Y & Z30DT Specific
    Last Post: 10th August 2012, 21:29
  3. 3.0CDTI - want one!
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 19:13
  4. 3.0CDTi de-cat
    By Celes in forum Diesel Engine related
    Last Post: 27th February 2010, 01:53
  5. Looking to get a 3.0cdti
    By sidvish69 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 19:58
