Thread: Noisy Graphics card pc
    Jun 2013
    Skelmersdale, Lancashire
    Trim : SRI
    Engine : CDTI 150
    Default Noisy Graphics card pc
    Anyone had any experience with a powercolor R9 290 graphics card?
    Reason i ask is i bought one an its one of the loudest cards i've ever had!
    is there any way to make it any quiter? As i actually have to turn the tv up to drown out the fan noise!
    Any suggestions before i send it back? Card is this one:
    Dec 2011
    Seaham
    Sounds like a duff cooling fan, send it back.
    Regular Member courtylad's Avatar
    Aug 2013
    Lancashire
    Trim : Sri/Cloth
    Engine : 1.8
    Was it always noisy from new or just recently? They naturally run hot so the fan goes at some speed to maintain some sort of effective cooling. AMD acknowledge this and have just brought out a card with built in watercooling to keep the noise levels down.If it's only recently then the fans bearing is on its way out. Do some digging on you tube for benchtest on your card to see if they sound similar under load.Last year i bought 2 7970's with 2 fans on each for extra cooling and were shocked buy how hot they ran and how noisy they were too. All gpu cards now run very hot due to the demand of all the newer games...so we pay the price....noise or watercooling. Hope this helps.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    i normally buy fanless cards. noise free. it just comes with massive heat sinks, and if you've got other cooling sources in your case then it will still run perfectly cool.
    Sep 2013
    Leicestershire
    Trim : SRi 100 Edition
    Engine : 2.0T
    AMD's are loud, but Windows might not be scaling back the fan speed properly though - at full chat the fan on mine drowns out 5 case fans and the CPU, at lowest speed it's barely audible.
    Jun 2013
    Trim : SRI
    Engine : CDTI 150
    I bought the card as an ex display, at first i thought it might be the thermal paste thats making it run warmer so the fan has to work harder, took it off and this is what i was greeted with:
    Cleaned it up as much as i could:
    it lowerd the temp by 1-2c but the fan still kicks in the same, so i downloaded afterburner and alterd the fan curve.. still just as bad haha
    would it be best to try and watercool it?
    Sep 2013
    Leicestershire
    Engine : 2.0T
    Are you running the Catalyst drivers and control centre?
    In Control Centre go to Performance - Graphics Overdrive - You can see the actual fan speed as a % as well as the temps. You can also set the fan control to manual, wouldn't do that permanently but you can at least set it to the lowest & highest setting to see how much difference there is, and if it's worth mucking about to get it slower.
    Jun 2013
    Trim : SRI
    Engine : CDTI 150
    i will have a look tomorrow as i'm out now.
    Here is a vid of it after about 5 min of playing Watchdogs:
    http://s736.photobucket.com/user/Har...sort=3&o=3
    Aug 2013
    Lancashire
    Trim : Sri/Cloth
    Engine : 1.8
    Summertime is always a testing time for gpus and poorly cooled cpus. Does your case have plenty of fans,does it sit where it can get plenty of air? Your options...if you go water cooled are get a conventional set up block,pipes pump etc....or there's a cheat...a cheap h80 type cpu cooler and cable tie it to the gpu board and just get memory cooler blocks for the ram. Or get a louder tv or move the pc to a different room...preferably soundproofed :-)
    Sep 2013
    Leicestershire
    Engine : 2.0T
    This is why I have 5 case fans - AMD cards run hotter than Nvidia's in my experience and don't cope as well in the summer.
  1. For Sale: Asus AH4650 HD Graphics Card 1GB
    By Ademusic in forum General items for sale
    Last Post: 3rd May 2011, 21:26
  2. Faulty Graphics card EBAY Rant
    By bigmac in forum The 'Off Topic' room
    Last Post: 30th July 2010, 15:12
  3. Graphics Card Advice Please.
    By Mark The Cabby in forum Games Room
    Last Post: 10th July 2008, 22:27
  4. Brand new 256 graphics card
    By lochgilp in forum General items for sale
    Last Post: 28th December 2006, 11:32
