Thanks Thanks:  1
Results 1 to 10 of 11
Thread: cigarette lighter removal
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    confused cigarette lighter removal
    My lighter works intermittently which makes charging the phone a pain...Any ideas how I remove it?.. I have got the surrounding panels/parts off and cant work out how to remove the broken lighter.
    I bought a Halfords replacement...is the wiring the same?..
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    Unplug from the wiring loom and squash it with pliers and screwdrivers.
    Aug 2016
    Croatia
    Vehicle : 1.9 CDTI
    Trim : Vectra
    I'm trying to remove lighter, but it seems like mission impossible. Its stucked and I cant get it out either way. Is there any advice how to take lighter out without breaking it? IMG_20161104_185139.jpg
    Many tnx
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I couldn't get mine out without breaking it. Ended up getting another from a breaker..I was able to break the surround to remove it.
    Aug 2016
    Croatia
    Vehicle : 1.9 CDTI
    Trim : Vectra
    It's weird...there must be a way to take it out of the hole. How did you put new one in? Is it possible to change the bulb inside without taking out lighter?
    May 2014
    Sofia
    Vehicle : Opel
    Trim : Vectra C
    Engine : Z18XER
    It's quite tricky, there are two pins that holds the metal part to the plastic one.
    You need to lever them out, to be able to pull the metal part and then the plastic one.
    I've tried with small flat screwdriver ... but for some reason I couldn't do it :-(
    Then I tried to turn the metal part counter clockwise, so I got the pins off the slots and then I managed to pulled it out.
    But a couple of months after that I tried to that again ... couldn't do it :-) I had to pull the whole console out :-(
    PS: according to TIS, you could just use a flat screwdriver to lever up the metal part ...
  7. Thanks Inovator thanked for this post
  8. #7
    Aug 2016
    Croatia
    Vehicle : 1.9 CDTI
    Trim : Vectra
    Success! After few hours od fiddling and sweating...
    Whats the type of the bulb inside, there's no code on it...IMG_20161106_121106.jpg
    I believe it's 1.3W
  9. #8
    Full Member RBH's Avatar
    Jan 2008
    Central Scotland
    103 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
    It's just a small capless bulb mate.
  10. #9
    Jan 2008
    Central Scotland
    103 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Mileage : 46k
  11. #10
    Nov 2016
    Sofia
    Vehicle : Vectra C Estate
    Trim : Life
    Hey guys,
    Will a cigarette lighter from Astra G fit on my Vec C?
  1. cigarette lighter/ power socket removal...
    By paul.sessions in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2016, 19:06
  2. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  3. No Cigarette Lighter
    By kingy999 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2010, 21:46
  4. Re: Cigarette Lighter
    By ope126 in forum Styling
    Last Post: 19th December 2006, 22:32
vectra c cigarette lighter removal
vectra c cigarette lighter trim
