Thread: Emergency - Please Help - Boot Won't Shut
    Regular Member Ian's Avatar
    York
    Default Emergency - Please Help - Boot Won't Shut
    Hi all,
    I hope someone can answer this quickly,
    my bossess car - a 06 plate 1.9CDTi SRi - the boot will not shut. There is nothing stopping it and it will close so the panels are level, but wont actually lock, so the boot will spring open when and as it likes. Weve tried unlock and lock on the key, on the door with the ignition on, engine on etc but no luck. The catch is free on the boot door and moves okay when prodded by a key - has anyone any suggestions as its stuck in the car park with £30k of survey gear in it!!
    oh forgot to say its hatchback.
    Feb 2007
    North west
    have a look at the lock with it open - is it stuck locked ? happened to me on a car once (wifes fiesta I think) and it was a jammed lock, I had activated the lock when the boot was open and it wouldnt shut. I used the key not the remote and some wd40 to free it up - remember you will have been trying to slam it so may have jammed the lock a bit.
    York
    cheers rob, but theres no key on the boot of the vec.
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Hi Ian, not sure on this but i do know that when you unplug the battery leads the elec windows reset, maybe the locks will ? unless it has failed good and proper !
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    right i had this problem.. the way i got around it was to keep shutting it until it locked.. you can offer something up the size of a screwdriver to test it.. Hold the screwdriver horizontal into the latch as it would be if you was to shut it. Push it up and see if the latch bites and locks... then release with the boot switch... i found after doing this it would lock again for a while... Vx told me it was due to air pressure in the cabin at first!!! 2nd time i went back i stuck to me guns and asked for a new boot latch.... Fitted it myself and not had any trouble since (touch wood)..
    York
    Cheers Dean, we tried that but the latch wont stay put. I think whatever the thing is that keeps that latch in place (solenoid?) has gone. The light id on the dash all the time, so may its sensor thing tellign the electrics that the boot isnt shut.
    I had this a few weeks ago...
    The car had been in for the tailgate fault, had to phone the dealership back on getting home
    Raise the tailgate
    Insert a screwdriver into the hole next to the lock and PUSH
    Insert the key into ignition, turn to electrics on, press tailgate unlock button, remove key from ignition
    The lock motor should now be heard (which it was)
    Lower tailgate and close
    If the tailgate does NOT lock the motor and/or electrics have failed, and to bring the car straight back
    However, it worked for me, and the lock has worked correctly ever since
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Raise the tailgate
    ok, anyone any ideas?
    i can only see 2 holes near the lock, one accessed via a bung in the interior trim, the device behind the trim only seems to rotate. the other hole seems to be a drain hole.
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    couldnt be bothered playing around with the lock any longer, so i stumped up £42 for a new one from VX, quicker & easier in the end, thats if anyones interested.
  1. My boot wont shut properly! Mighr have blown something!
    By Innes in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2012, 18:20
  2. Boot wont shut porperly. Think i've blown something!
    Last Post: 12th May 2012, 21:53
  3. Emergency pls help me
    By myelite150 in forum Diesel Engine related
    Last Post: 25th April 2010, 18:20
  4. boot wont shut !
    By nigec in forum Bodywork & Interior
    Last Post: 17th January 2010, 15:08
  5. Signum Emergency Boot Release
    By O5prey in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 23:44
vauxhall vectra boot wont shut
insignia car boot wont close
vauxhall vectra boot wont lock
vectra boot wont close
boot not closing on 04 vectra c
lock jammed on car boot astra it will not close
vectra c boot wont shut
Astra Mark 5 tailgate is locked wont phone
vauxhall astra boot wont close
Astra Mark 4 tailgate wont shut
astravan tailgate not closing
vauxhall insignia boot not locking m
cant open car boot vauxhall vectra c
vauxhall insignia boot wont stay shut down
opel zafira boot wont close properly
vectra b faulty boot catch
vauxhall zafira boot wont close
insigna boot not locking
2009 astra boot wont shut
vectra c wastegate dont close
why wont my boot close on vectra
boot wont close meriva
vectra c trank wont close
Opel Astra trunk not closing
vectra electric tailgate wont close
