Thread: Aerial connections to CD 70
    Mar 2007
    Default Aerial connections to CD 70
    I am trying to fit a Denison FM transmitter to connect my I-pod via the aerial socket. The CD 70 has two, presumably one for the sat-nav and one for the radio. Any ideas which is the FM?? Does any one have access to the wiring diagram?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The ariel connector is a type called fakra,a small square type the same as Bmws,easy way to tell which one it is, just unplug one and see if it still picks up fm.
    Mar 2007
    Default Aerial connection to CD 70
    Thanks, I thought of unplugging one, but the before the unit is far enough out of the dash to do this you have to unplug the connection to the display screen. I did not want to run the head unit with the screen unplugged in case it damaged it.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Bit of a pain, but you could unplug all the connections and then refit leaving off one of the ariels.When you turn the stereo on you'd either lost gps or fm.
    Regular Member andrews70's Avatar
    Jun 2007
    cleethorpes
    Did you have any luck with the Dension?
    I have been trying to get a system for my CD70.
    The aerial wire carries 12 volt through the centre core.
    Did this affect the radio signal?
    Mar 2007
    Yes it works OK, the FM signal was dsitinctly worse with the Dension in line, I think due to the poor fit of the adaptors supplied with the kit. It is not really noticeable when the ignition is switched on. When you turn of the ignition the Dension powers off and pauses the Ipod. The radio then crackles like hell until you pull the key out and the radio turns off. If you want to sit in the car and listen to the radio on an FM channel you must have the ignition on otherwise the signal is too poor to listen to.
    I did get a bracket from Brodit. this fits real well and is solid but sits over the air vent slightly. This partially blocks the view of the CD70 screen. If you move it over the passenger side it is a bit of a stretch.
    All round a bit of a compromise. The sound quality of my previous Alpine unit with proper interface was fantastic but if you want to keep the sat-nav etc than a compromise is to be made.
    Oct 2006
    Wellingborough
    Where did you take the power for the FM transmitter? if it's from a power source that's ignition live only then you will get rubbish FM with ignition off. similar principle to unplugging your VCR while watching telly.
    Mar 2007
    Yes, I understand why it does it, there are permanent live and ignition live connections for the Dension. I took the ignition live from the fag lighter. It doesn't bother me that much, but it proves the reduction in FM signal caused by the unit. I am sure that if the ignition live is made from a permanent live then the drain on the battery should be negligible. The good feature of the ignition live is to automatically pause the i-pod when you switch the engine off.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    A little clarification...the fm aerial on the back of a CD70 NAVI is the white / cream coloured plug and socket
    The GPS aerial is the blue plug...and socket.
    and as said by Tyreman...they are called Fakra connectors...VDO will do adapter looms etc for interfacing with standard aerial items etc.
  1. What connections...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 13:33
  2. BSR PPC connections?
    By FiscusFish in forum Diesel Engine related
    Last Post: 30th April 2008, 15:33
  3. ISO connections
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 00:21
  4. PS3 Connections?
    By Stevel in forum Games Room
    Last Post: 9th December 2007, 22:57
