Likes Likes:  2
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Retrofitting Auto Lights and Auto Wipers
  1. #11
    Regular Member ianwat23's Avatar
    Gateshead
    Vehicle : Vectra Sri 120 navi
    Trim : Sri
    Engine : 1.9 cdti 120 bhp
    Mileage : 38550
    Supposed to canbus. Not cannula. Ha ha
  2. #12
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by ianwat23 View Post
    Cheers woody. I've got the ex sensor and had a full cannula roof loom but didn't realise that the main interior light/alarm unit wiring was snapped off. I put thepre facelift loom back in to get all the lights working again. What is the difference with the facelift and pre facelift wiring? I could try and splice the canbus loom in somewhere. Unless someone has a full can bus loom for sale I could buy����
    You won't need a full loom. The rain sensor loom is a seperate one (although they are all taped up together, they can be seperated).
    The preface rainsensor has a different plug on the end of the loom to the facelift one, so you will need that loom for that reason.
    The plug into the REC is the same though, it's only the sensor end of the loom that is different
  3. #13
    Gateshead
    Trim : Sri
    Mileage : 38550
    The plug on the facelift loom was damaged so I took it off that and fitted it onto the pre facelift loom. I've tried the wiring both ways in the plug but it makes no difference. I can unplug the sensor and the auto lights still come on. The wipers do nothing at all. When it was tech2d I heard something about a short in the sensor but it may be the loom somewhere. All I can do is separate the canbus loom from the sensor and plug that into the rec and see if that makes a difference. ����
  4. #14
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    do you have the rain sensor activated in the UEC? - it controls the wiper motor and lights
  5. #15
    Gateshead
    Trim : Sri
    Mileage : 38550
    That's the thing, I'm not sure he went into the uec when he programmed it. In going to go back and see if he did.
    Ge better not try and charge me again for the tech2 session. He messed up the first time.
  6. #16
    Gateshead
    Trim : Sri
    Mileage : 38550
    A follow up to this problem. The headlights still work the same as before. The auto wipers still don't work. I've had tech2 on car and it has said short in headlight switch(dash dim switch). Has anybody come across this?? Is a new switch needed to solve this? I have heard somewhere about a
    wire going into rear of headlight switch but don't know exactly what the deal is.
    Any advice would be great.
    Ian
  7. #17
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    Ian
    Could it be the wrong headlight switch? I think @Z80 has mentioned that there's an auto light switch for preface signums that's wired differently
  8. #18
    Gateshead
    Trim : Sri
    Mileage : 38550
    I've got another switch in now. It all works the same but I can dim the dash lights now, whereas before they wouldn't dim at all. I've not had tech2 on yet to check if it's "fixed" that fault code. Once I've had it checked I'll post on here if it worked or not. ��
  9. #19
    May 2012
    240 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by Woody View Post
    Sorry mate. I have mislead you there. The rainsensor is integrated into the main loom. It is the dimming mirror which is seperate.
    Hope that hasn't confused too many issues there
  10. Likes Blackie_No1 liked this post
  11. #20
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    The switch is only about ordering the BCM to activate auto lights mode.
    It has nothing to do with the wipers.
    However, for the auto wipers to work, maybe you need a stalk having the sentitivity roller on top of it ? I don't know if they're the same as for cars without a rain sensor (provided there are some). Or maybe the roller works as a speed control in this case.
  1. Retro fitting Auto lights/wipers?
    Last Post: 16th June 2013, 22:09
  2. The start of my mod to auto wipers and lights
    By jon1.9cdti in forum Styling
    Last Post: 8th May 2012, 12:29
  3. Auto lights/wipers and 'frost'
    Last Post: 20th January 2012, 11:55
  4. auto lights and wipers not working
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 14th December 2011, 22:07
  5. Possible to fit auto lights/wipers
    Last Post: 13th October 2011, 19:10
https:www.vectra-c.comforumshowthread.php207255-Retrofitting-Auto-Lights-and-Auto-Wiperspage3
vectra c auto lights
vectra c auto light switch activate
https:www.vectra-c.comforumshowthread.php207255-Retrofitting-Auto-Lights-and-Auto-Wipers&goto=newpost
did preface vectra c come with auto lights
Vectra C retrofitting options
vectra bcm type kh auto light
vectra bcm auto light
vectra c auto light bcm
auto lights vectra c
asd auto lights to vectra c
retrofit auto wipers on sri
retrofit auto lights vectea c
auto light on vectra c
vectra c auto wipers retrofit
vectra c auto light switch from bcm
how to install vectra c auto lights and wipers
auto lights and wipers vectra
fitting auto wipers
vectra c auto lights bcm
retro fitting auto lightswipers to vec c
vectra c auto loghts and wipers
vectra c retrofit
