Results 1 to 10 of 23
Thread: Turbo It Cheap?????
    Feb 2007
    mexico
    Default Turbo It Cheap?????
    do you guys think it would be a good, safe and cheaop idea to buy and install the vectras new turbo, the one on the 2.8 v6 on a old 2004 3.2 vectra? you buy the parts cheap from a totlaed car whose turbo parts are unharmed...?????
    nope, as the internal engine design of the 3.2 was never built to have a turbo fitted..the 2.8 will run a lower compression ratio to cope with the extra boost the turbo gives it..and if you intend to give it sustained hignh boost pressures then you'll be looking at extra oiljets to cool the undersides of the pistons and better quality pistons ( to avoid melting) and a better headgasket.. too much work IMO..
    Better to supercharge it..works on much lower boost pressures..
    Regular Member The Doc's Avatar
    'Norf Yorks.
    You could do what Courteney do and use twin head gaskets and an adaptor plate between the head to lower the compression.
    Ball ache though?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    or just take the lump if unharmed from the vxr and dump it in??
    Feb 2007
    mexico
    whats a lump? and what supercharger is fitable on the vectra? thanks
    [Ex]Admin Duncan's Avatar
    'lump' is a slang term meaning the whole engine.
    Regular Member Robward27's Avatar
    Witham
    then you have the dreaded canbus system to overcome lol.
    Jul 2006
    Northampton
    Trim : Sri
    chop shop job lol
    Regular Member Ian's Avatar
    York
    As GSi has said, totally possible conversion, but added to the the new pistons, oil jets, head gaskets you'll most probably need stand alone engine management and maybe new high flow fuel injectors, or a seventh injector somewhere. Its got to be cheaper and easier to drop in a VXR engine.
    If you do decide to do it anyway it'll be the most unique vectra - c I've ever seen!!
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    There is that phrase again - Canbus
    What is the Canbus. Have seen it on many a thread but haven't a clue what it is!!
  1. Turbo hose kit. Cheap???
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2012, 23:12
  2. cheap signum turbo
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2012, 21:54
  3. This 2.8 = V6 Turbo seems a bit cheap .
    By HITFACTORY1403 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2011, 14:49
  4. cheap sri turbo
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 18:13
  5. cheap turbo
    Last Post: 20th September 2010, 07:21
