Results 1 to 10 of 11
Thread: 1.8VVT Gear Linkage
    Apr 2013
    Luton
    Vehicle : Vectra C Hatchback
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Default 1.8VVT Gear Linkage
    The stiffness in and out of gears isn't getting any better especially first where sometimes can't get it in without pulling back and giving it a waggle.
    Already changed the oil and lubed both ends of the linkage.
    Anyone found a good price for a new linkage?
    Anyone know how to do the adjustment?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    This is something I want to do myself, it looks complicated, but it is probably easy when you have done it.
    Here is the link I am saving for when I have a go, but I'm sure I remember seeing a better one with more pictures, but where?
    http://www.vxronline.co.uk/forum/sho...a-Gear-Linkage
    Regular Member FatboySteve's Avatar
    Bedfordshire
    Hardest bit i found was pressing in the securing clips
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Thanks Tony yep it would have been easier if the pics were there, Steve have you got any instructions and where did you get the linkage?
    Ta.
    Bedfordshire
    I didn't get a replacement linkage, i did something similar to what the Saab repair kits (http://www.youtube.com/watch?v=CFd_zp4f7GY) do.
    Watch the video, it will explain what the problem is, if it's the same as mine anyway.
    Is it side to side movement which is a problem ? ie, difficult to get into first and Very difficult to get into Reverse?
    Bedfordshire
    Just re-read, It's probably not even the same gearbox, so may not be relevant.
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Thanks anyhow Steve.
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Anyone know how to set up this linkage?
    Bedfordshire
    Internally it will be the same as the above link, unclip cables, drop the clip bit, and fix the lever in place.
    Next will be remove battery box, and If it's anything like the F40, there is a hole which you can align, and put a drill bit in to lock it in place.
    Then simply connect the cables back up inside.
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Thanks very much Steve. A How To on this would be a good thing for many members methinks.
  1. Gear Linkage Removal
    By stevie16v in forum Engine & Drivetrain
    Last Post: 4th July 2013, 19:05
  2. Corsa-C Gear Linkage
    By LJ sxi-nav in forum The 'Off Topic' room
    Last Post: 8th June 2010, 14:39
  3. Gear linkage knackerd
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2009, 14:32
  4. Manual Gear Linkage ?
    By 900ss in forum Engine & Drivetrain
    Last Post: 24th June 2008, 14:14
  5. Gear linkage cables
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 15:19
vauxhall vectra 1.8vvt gear
