Thread: 2.8NET pop off valve
    Mar 2007
    Netherlands
    Default 2.8NET pop off valve
    Hello,
    I want to place a pop off valve (dump valve) on mij vectra OPC
    Is there maybe anyone who knows if this is posible?
    And where i can get the valve.
    Greetings Erwin
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    had a look around and a mate says try demond tweeks and see what they can do
    Others have fitted 'forge motorsport' valves to there's.. try an internet search engine to locate a dutch supplier?
    Mar 2007
    Netherlands
    i heard there is a problem when you put a valve on the car somthing with the software?
    Regular Member rickyroo's Avatar
    shropshire
    fit a hks sqv valve works well with bsr map, mines on order and it's a direct welded plate to the turbo set you back £325 quid, will work upto 420bhp.
    What all subarus, skylines and alike use.
    Speak to mij performance in walsall they will sort you out.
    Mar 2007
    Netherlands
    Quote Originally Posted by rickyroo View Post
    Do jou maybe have an webadress from bsr ? and hks?
    Greetings Erwin
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
