Thread: Would a CCR2006 fit into a LS which has a CDR2005 fitted currently?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Would a CCR2006 fit into a LS which has a CDR2005 fitted currently?
    Strangely, the title says it all.
    [Ex]Admin Duncan's Avatar
    Yes, straight swap and no need to mess around with any Tech 2.
    Edit: I must have posted seconds before you solorider!
    Hadn't realised about the cage. Why's that then? They're both double DIN units aren't they? Is it the bits in the back of the cage that's different?
    Regular Member solorider's Avatar
    swindon
    yes but you will need the cage
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    same cage, but the cdr 2005 has the flaps on either side of the cage folded in to hold the stereo as far as i know
    Regular Member graham a's Avatar
    hull
    the cdr 2005 cage has a lip in the middle,to support the top part of the head unit.all i did was take the 2005 cage out,then bent this lip up so my ccr2006 fitted in,worked a treat
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    THX
  1. For Sale: ccr2006 and cdr2005
    By jpbroad1970 in forum Parts for sale
    Last Post: 4th July 2012, 21:10
