Results 1 to 10 of 13
Thread: cdti 150 oil filter
    May 2006
    North yorkshire
    Default cdti 150 oil filter
    i feel really stupid but where is the oil filter located on the cdti 150 engine cos i just can't see it
    morton
    i think its an element filter ! should be down th front of the engine with a hexagonal black top on it ! nothing like a normal filter !
    May 2006
    North yorkshire
    thanks, yeh i knew it was a filter element but couldn't see the hexagonal top but will have another good look tonight.
    it's actually down the BACK of the engine, about 1/2 way down, sticking out on an alloy casting..black plastic cap with a 32mm hexagon on top of it.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    has a little silver spout sticking out the side of the housing...
    when you unscrew the black cap, the top half of the housing comes away.. you can see it physically turning as you do it.. Mind out for the little spout cause once you undo it a little way oil comes through it.. Let it drain for about 5 mins or so otherwise you'll get soaked lol..
    Not that i did it tonight wheni got home from work, and not that i got soaked neither (need a shower)
    May 2006
    North yorkshire
    thanks for that i'll have a go this weekend. i will make sure sure im wearing my rubber suit
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Finished my oil change today.. now i got the right filter. Not a bad job once u done it once.. Oh and when you come to tighten it up, there not much room underneath with a 1/2 ratchet and 32mm socket. i put it on the nut and then climbed onto the engine and stretched down the back of the engine. much more grip on it.
    Quote Originally Posted by plasma View Post
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    can someone do a how to or something with pictures please as i`d like to do this myself,with changing the oil throw my flexi service thing out? is it going to go up and tell me i have longer to go? what oil should i use do i get it and the filter from vx i notice on my invoice it just says mobile for the oil
    There's a How 2 in the How 2 section that I did a while back. It's 2.0T specific (in terms of parts and location) but the principle is exactly the same).
    Ref your flexi servicing, are you doing this as an additional change to your service schedule? If so, then you don't need to do anything, or worry about anything, regarding the service reset. If this is a scheduled oil/filter change then you'll want to reset the service indicator. It's mentioned in other threads - I can't recall it off the top of mu head.
  1. Help!!! CDTi oil filter
    By 123rado in forum Engine & Drivetrain
    Last Post: 17th March 2012, 18:58
  2. cdti air filter help
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 19:51
  3. 1.9 CDTi oil filter
    By dalcock in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2010, 18:43
  4. What oil filter for 1.9 cdti 150 ?
    By Fash in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 20:04
  5. V6 CDTI Air Filter
    By r.bailey63 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 01:16
