Why does my Xbox360 keep freezing up when I'm owning people on BF4 but not when I'm having a bad day!?
Because bf4 sux and you should be putting all your efforts into cod ?
I've repaired a fair few 360s in the past. Usually just needs all the dust hoovering out of it although they some times need the thermal paste renewing.
cos your too good and it canny keep up
Easy to get in yes, but will void your warrenty
http://m.youtube.com/watch?v=qaxIB6cXTYM
If' cleaning it out doesn't fix the problem it may be just issues with BF4?? It's well known for connection issues..
Have you cleared your cache? if not clear it out three times and see how you get on..
Have you tried Titanfall? I've got it on both XO & X360, I usually prefer single player games, but i'm hooked on Titanfall at the mo..
I only have bf4 I only play the online on it when I get chance which isn't often, I'll try the cache clear then if that fails I'll open it up and give it a good clean, it's a 5yr old pre-owned so it's doing well so far!
I still have my Dec 2005 launch day 20gb X360, (among others) it still works fine..
Also, check your Primary & Secondary DNS are set ok, there's some malware out there that changes the DNS settings on your router so that all your search results etc are run through the changed dns servers, so if you have the Xbox set to obtain DNS automaticly they will also be changed, I use Googles DNS on mine now.. They are Primary 8.8.8.8 and Secondary 8.8.4.4
Hope you can get back into games without freezing..
