Thread: Problems already! No power in 1st/2nd
    Oct 2013
    Glastonbury
    Engine : 2.0T
    Default Problems already! No power in 1st/2nd
    Hmmm already got a problem with my 2.0T the spanner light came on and noticed no power when pulling away it really struggles in 1st and 2nd seems to pick up in 3rd. Can't hear any boost. Not sure what it could be any pointers on what this could be. I've got an old fault reader elm327 which plugs into a laptop not sure it will work with the car not tried it yet. Any help much appreciated.
    car is a 55 plate signum 2.0T
    South east
    Oct 2013
    Glastonbury
    Engine : 2.0T
    Ok cheers will try that as we'll the light has gone now but I'm sure it will return when I drive it. Also is the obd connector that is under the ashtray a different kind as I thought they were all standard. Mine didn't fit.
    Oct 2013
    Glastonbury
    Engine : 2.0T
    So pulled these codes:
    2135- throttle position sensor?
    1682 - no idea what this one is
    any ideas could this be the accelerator pedal issue?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    on my 2005 2.0T it was the throttle pedal that was causing that symptom but it sorted itself out after a few days while i was waiting for a spare to arrive, I did not fit the spare in the end, its still on my shelf... I am not saying thats defo your solution but its a cheapenough start so long as you have cleaned out your throttle body and checked your boost solenoids..
    the second code may indicate an impending alternator failure
    Oct 2013
    Glastonbury
    Engine : 2.0T
    Cheers. Also the plug under the ashtray looks completely different to a normal obd port I will get a pic up. Am I missing something here?
    Oct 2013
    Glastonbury
    Engine : 2.0T
    See the attached image looks nothing like an obd connection. Is there another adapter type thing that's not there?
  1. Power Steering Problems
    By Brooky18 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2011, 21:31
  2. power problems
    By DavieVectd120 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 17:21
  3. HELP!! Fed up vec owner - now having power problems
    By Vecmaniac in forum Engine & Drivetrain
    Last Post: 27th February 2010, 18:53
  4. Power problems
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 10:28
  5. 150 CDTI Power Problems
    By multi in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:58
