Results 1 to 9 of 9
Thread: Possible air con problem
    Feb 2007
    Essex
    Default Possible air con problem
    Does any one know at what outside temperature air con should start working ?
    Don’t think my mine is working. Today had an outside temp of 17 Degrees so I tried the air con and the light came on but the air didn’t feel cold and also didn’t notice any extra load on the engine.
    Looked in the Handbook to see what the minimum outside temp air con will operate at, but the book just says “At low outside temperatures the cooling unit switches off “
    Technical directors office
    had mine running this morning at an outside temp of 8 degrees.. so i wonder if yours is short of gas..that'd make it cut out on the low pressure switch....
    i think it temps out nearer freezing point..
    Feb 2007
    Essex
    Thanks for the info
    Thought there was something wrong with mine. Looks like an expensive trip to a specialist before the hot weather starts.
    Regular Member AndrewTi's Avatar
    Feb 2006
    Guttedsville
    Shouldn't be more than £50 for a regas matey.
    get them to do a vac check and a nitrogen fill 1st... they should anyway.. to see if it's got any leaks..before they fill it with refridgerant..
    Feb 2007
    Essex
    Thanks for the tips. I'll make sure whoever does the job understands that I want the system checked before its re-gased. if Andrews estimate of £50 is about right then I think it will be well worth the money to stay cool.
    Aug 2006
    Is a very naughty boy
    The Nitrogen will remove any moisture from the system too that could freeze in operatio and block valves etc. I thought it stopped at about 4 degrees?
    it is down that end of the scale yes...at this time of night i can't remember it for the life of me..
    Mar 2006
    Nicking Ya Dinner.
    I think mines gone again, not happy, cos it looks like the supplying dealer told my Vx dealer just to gas it up again rather than pay for something that's probably not under warrenty, unless it was discharged to replace the heat exchanger and they forgot to recharge it.
  1. Problem...? Vectra SXI...problem with starting after filling with fuel?
    By doozer in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2022, 12:25
  2. Rear Signum Light problem problem - help
    By scw02102 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 21:12
  3. Wiper Electrical Problem? (Not sticking or cold weather problem)
    By SRIAdam in forum Electrical & ICE (including SatNav)
    Last Post: 7th July 2012, 16:13
  4. 1 problem sorted and 1 more problem arises
    By bunsen1 in forum Engine & Drivetrain
    Last Post: 4th April 2011, 13:03
  5. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
