Thread: 2.0dti cruise control
    Mar 2007
    ipswich
    Default 2.0dti cruise control
    hi all
    just bought a 2.0dti on a 52 plate and noticed the crusie control isnt working. ive noticed that the light on the dash doesnt light up when i start, ived tried lifting the pedals as stated in a few threads ive read and still nothing, any ideas as im off to france soon and the cruise would be nice to have
    Regular Member scar_vectra's Avatar
    Feb 2007
    scarborough
    My 03 1.8 elegance light for cruise control doesn't work....but the c/c does...also does your fuel light come on when you first turn ignition on its supposed to be next to the c/c light mine doesn't
    Mar 2007
    ipswich
    yep , fuel light and all other relevent lights come on, was thinking if my light doesnt come on its more than just a pedal or stick problem hopefully not then if yours still works without the light
    Feb 2006
    Guttedsville
    Sounds like it may be one of the switches under the brake or clutch pedal. Need to get your head right in there and take a look.
    Also, have you had a look at any of the fuses?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Or the stalk switch itself, or some thing more expensive, like the ECU or something else.
    If the switches checkout OK, then prob a trip to either VX or A.N Other would be helpful.
    Feb 2007
    Nuneaton
    I had the same issue. Very common fault. In most cases this is clutch pedal spring got loose or broken.
    The dealer can fix it. The spring costs is less then ten pounds plus labour (so be prepare to pay around hundred pounds ).
    Mar 2007
    ipswich
    hi, checked the clutch whilst out in it today and thats the problem, have to lift it before it engages. Can this be a diy fix or has it got to goto a garage(resent paying there over the price labour costs)
    cheers for all who replied
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Don't understand about having to lift it, lift what?
    The switch itself is easy to change, or is it the position? or the position of the pedal? A bit more detail may get good answers.
    he's getting at the fact that the pedal return spring won't lift it high enough to engage with the CC clutch switch..it normally leaves it hanging about 4mm short of the switches plunger.. so not closing it and leaving CC unable to engage..
    the easy test to see if it is the clutch switch is to just lift the pedal with your foot while driving and see if CC will engage..
    Changing the switch or the pedal spring just means removing all the trim around the column and pedal box for access.. a bit involved, but not difficult..
  1. cruise control help
    By chris1984 in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 20:10
  2. Cruise control on ice?
    By se4 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2010, 22:11
  3. Cruise Control MPG
    By Phatty in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2008, 15:59
  4. Cruise Control 2.0 T
    By neilbroad in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2008, 19:24
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
