Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Facelift Question regarding traction control
    Regular Member Pronto13B's Avatar
    Feb 2007
    Ripon
    Default Facelift Question regarding traction control
    Does the facelift have the TC or as its called now the ESP connectors under the blanking switch? And if so has anyone shoved a switch on and does it work.. sorry for the way i have worded this lol
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    I havent tried it, but I have read a few other threads on the site and it seems that NO is the answer.
    Something to do with the wiring on the facelift. The blue plug is there but it doesnt do anything!
    I am sure that if that is the wrong answer then someone will let you/me know!
    TC was dropped on the facelifts. The V6 Elite and Design have ESP+ as standard. As the others don't have TC as standard, the switch won't do anything. Not sure if there is even a plug behind that would at least illuminate the switch.
    Feb 2007
    Ripon
    Been reading the old user manual.. and took the car out for a little test the other day when wet.. if i floor it i get the warning sign with wigglely bit up to show some form of TC.... now i'm confused coz fishy gets the same if he does it.. so there is some form of TC.. totally stumped now
    There was a thread somewhere else on this (TC on the facelift) and people were saying that the facelift doesn't have TC - even though the brochure said it did!
    I'm now confused as well Ade! I gave the above info on what I'd read from some facelift owners. I'll go back in the corner and let them pop in a reply now!
    Feb 2007
    Ripon
    LOL... Sat here with a look myself.... may pop down to the stealship in morning and see what they have to say.. but i aint paying for a Tech 2 for them to find out if i have it.....
    This one has confused me big style
    Feb 2007
    Ripon
    Quote from manual
    Electronic Stability Program (ESP)
    ESP improves driving stability when necessary in any driving situation regardless of the type of road surface or tyre grip. It also prevents the driving wheels from spinning.
    The system monitors vehicle movements. AS soon as the vehicle starts to swerve (understeer/oversteers) engine output is reduced (the sound of the engine changes) and individual wheels are specifically braked. This considerably improves the driving stability of the vehicle on snow and ice and on wet or slippery road surfaces.
    ESP is ready for operation as soon as the ignition is switched on and control indicator (this is the warning triangle with car and wiggley line) goes out.
    Control indicator flashes when ESP is in action.
    So whats all that mean then lol
    Feb 2007
    As I understand it, the facelift vec will only have ESP if you have the sport button, which as I understand it means you will also have the TC button.
    Again I am prepared to be corrected!!
    Feb 2007
    Ripon
    Quote Originally Posted by sonicboom View Post
    Thanks for the info.. will go and speak to one of the Vx gurus and see if they can shed light on it for us...... seems strange they would remove TC from the range as its been on the B's and early C's.... my heads in melt down........ god i love Vx lol
    each car should come with a list.. saying you have the following lol
    only found the variable wiper speeds by accident lol
    Is it an early facelift, perhaps the first few had TC fitted ??
  1. Traction Control and ABS question
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 14:56
  2. Traction control question?
    By john1 in forum Engine & Drivetrain
    Last Post: 3rd December 2010, 20:53
  3. Vectra C facelift, 19 CDTI 150 No traction control..?
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2010, 01:49
  4. traction control question
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 01:36
  5. Facelift Traction Control Switch
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2006, 14:33
