Results 1 to 10 of 24
Thread: V6 CDTI air box mod (how to)?
    EVERYWHERE
    Default V6 CDTI air box mod (how to)?
    Read elsewhere that box can be modded.Is there an "how to"? does anyone know how it's done?
    Any help/advice greatly appreciated.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Did mine yesterday on the V6 CDTI, very easy indeed, just open the air box, remove the air filter then u will see the piece to be removed, simply unclip at the open end and gently silde the other end upwards and thats it really.
    EVERYWHERE
    Quote Originally Posted by r.bailey63 View Post
    Thanks.
    Does the ECU stay on the filter lid or is it removed.What's the best procedure?
    Mar 2007
    Stockton on Tees
    You will need to remove the ecu from the lid, no need to disconnect from the loom though
    EVERYWHERE
    Thanks again bud.
    Mar 2007
    Stockton on Tees
    No problem mate.
    Regular Member Xorro's Avatar
    Northants
    What does this mod do and what is the part to be removed?
    EVERYWHERE
    Quote Originally Posted by Xorro View Post
    Not sure if your facelift model is the same,bud?
    Mod apparently utilises more of the filter element.The pipe was only put in place so vehicle would pass noise restrictions.
    Regular Member Harry's Avatar
    Uxbridge, London
    Quote Originally Posted by diesel dog View Post
    i cleaned out my K&N filter over the weekend and it was still very noticeable that one side of the panel is getting used MUCH more than the other, and that's with the tube at the bottom removed.
    EVERYWHERE
    Quote Originally Posted by Harry View Post
    So,is it worth doing then?
    Is there any difference in performance,noise or whatever?
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
