Results 1 to 10 of 14
Thread: Cruise control problem
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default Cruise control problem
    The cruise control on my Vectra SRI V6 CDTI Auto, has developed a small fault, it all works ok until you try to speed up using the button on the end of the stalk, instead of speeding up it disengages the cruise control, sometimes it will work for a few seconds before disengaging. Anyone had any experinece of this?
    Feb 2007
    work
    your not touching the clutch pedal at all when doing it are you, as this will cut the C/C off.
    Oct 2006
    Yorkshire
    Default cruise
    ..yes, mine had the same problem...new stalk required
    Mar 2007
    Stockton on Tees
    Thanks guys, will try a new stalk.
    Dont suppose anyone has one laid around?
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by r.bailey63 View Post
    Not me, but this guy has two of them
    Regular Member simac's Avatar
    Wirral
    I have the same problem and have been told it's the stalk too.
    In fact, the way mine works it could be the clutch spring too ...
    Is changing the stalk a simple swop over job ?
    Mar 2007
    Stockton on Tees
    Thanks for that.
    Regular Member Sundance's Avatar
    Scotland
    Quote Originally Posted by simac View Post
    just give it a good hard pull straight out, can be a bit tight but they slide back in easy!! No programming required.....plug and play is what they say!!
    Feb 2007
    SO31 9BD
    I had the same fault - it is known Vecta design fault and Vx did a standard upgrade for free.
    Regular Member andy d's Avatar
    Feb 2006
    Inverkip
    Mine done it for a couple of weeks but seems to have sorted itself out!
  1. cruise control problem
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2012, 22:07
  2. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  3. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  4. cruise control problem
    By Herman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 19:10
  5. Cruise Control problem, HELP pls
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 11:06
