What width are the standard Club alloys, are they 7" or 6"
Anyone please
just looked through the owners manual and found nothing really ... but if you take one of your wheels off it should tell you on the reverse side
ie 16x7j or similar ..will also tell ya the pcd ( distance between the holes ) ....and your et ( where the wheel hub sits in relation the the center of the alloy ) ie ; et45 or similar
so take the wheel off mate and all your questions will be answered![]()
Ta Big Phil, the reason i ask is because i am replacing my steel's with some alloys when i get some eventually, would 17" off a Signum fit and will my wheel nuts fit the alloys?
Straight swap mate... just need different tyres (to the ones on your steels, if the alloys come with tyres it a winner, no hassle at all).... The vec will swallow anything up to 20" into those cavernous arches..... no matter what spec you are in the range you will have no probs fitting any 5 stud wheel in te VX range, as long as it bigger than 17" to go over the brakes etc!Originally Posted by prm
And the nuts are ok?
