Thread: noise when cold
    Regular Member jamesr's Avatar
    Lancashire
    Default noise when cold
    When i start up the car i get a sueaking noise, i think is coming from each the cam belt area or alternator/air con?
    It sound like a belt slipping or something?
    Disappears when warm
    Any ideas how to cure?
    [Ex]Admin Duncan's Avatar
    What engine?
    Lancashire
    opps sorry
    1.8
    Mar 2007
    England
    Sounds like the alternator belt. Same thing happened to mine, changed the belt and it went away for a bit.
    I think the tensioner wears the belts quite quickly as mine was squeaking again within 5k miles
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    deffo sounds like a new belt needed at worst a tensioner
    Lancashire
    How much for the belt?
    And how easy to fix myself?
    the belt will set you back around £25 .... easy to fit too.. 15mm spanner for the spring loaded tensioner.. just draw yourself a diagram of where the belt goes before you take it off....
  1. Cold Start - Blowing Noise...
    By dexter69 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 16:07
  2. squeaking noise when cold
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 15:47
  3. noise when cold (clutch?)
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 19:58
  4. Z20NET Tapping noise when cold
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 2nd February 2010, 00:17
  5. Grating Noise When Cold
    By ANDREWS in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2008, 18:21
