Thread: Any mechanics online?
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    Default Any mechanics online?
    I'm trying to change a cambelt on a citreon berlingo, & i'm having trouble releasing the crankshaft pully bolt.
    I've tried all my might and it wont budge.. anybody on any suggestions?
    I was toying with the idea of applying heat, would this be a bad idea?
    cheers,
    Mileage : 55000
    Is it a left hand thread??
    Quote Originally Posted by ed taylor View Post
    lol I hope not because Iíve bin tightening it if it is.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    I've seen people put a socket or spanner on the nut,turn the engine so the end of the spanner or nut bar is against the chassis and then give the engine a quick turn over on the key - power from the starter is usually enough to budge it
    Regular Member Ali's Avatar
    Northern Ireland
    The obvious one is an airgun.It will be r/h thread.
    You could try putting it in gear(4th) have someone hold the footbrake on hard and use a pull bar, this usually works if you don't have access to an airgun.
    Quote Originally Posted by Ali View Post
    You could try putting it in gear(4th) have someone hold the footbrake on hard and use a this usually works if you don't have access to an airgun.
    r/h thread thats good... i was going the right way then.
    I was using a socket set with a extention bar, managed to snap the extention bar, and take off all my knuckes on the floor....
    Quote Originally Posted by IamtheStig View Post
    well after trying just about everything i had to hand, i thought ****** it, suck me socket on the pullybolt, closed my eyes (tight) .... and gave it a quick flick of the key....
    It came out first time! wish i'd tried this first now..
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Nov 2005
    Somewhere in time
    Jobs a good un...
  1. Any mechanics that can fix my car?
    By mclayson in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 08:37
  2. COW Boy Mechanics?
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 13th April 2012, 18:50
  3. one for the mechanics?
    By Critch in forum Diesel Engine related
    Last Post: 24th April 2011, 00:40
  4. WII online.... can you play online
    By m3ath3ad in forum Games Room
    Last Post: 26th April 2009, 22:12
  5. vx mechanics
    By bish in forum General Chat
    Last Post: 22nd February 2008, 15:02
