Thread: signum towbar
    Jul 2006
    hartlepool
    confused signum towbar
    hi every one, i've just fitted a tow bar to my signum, 2004 2.2dti, it is a witter towbar with vauxhall wiring, i,ve fitted the towbar and the electrics just plugged in to the rear fuse box, connected the earths etc, a friend from my local dearlership coded in the towbar, now were both baffled as it wont work, has anyone had any problems like this and please how do i fix it it?
    Leicester
    Can't help here, I have the Vauxhall 12S and 12N electrics and both work OK.
    Have you plugged in the black box?
    Jul 2006
    hartlepool
    black box matey? all i got was wiring from the pluds going to a connector which plugged into the fuse box, and wiring that plugged into fuse space13, which feeds a relay for the caravan aux socket, dont recall any black box?
    It should have come with the big black control module.. a plug in box that fits into the rear fuse panel...that controls the functions of the towbar..
    if it wasn't in the kit, you'll need to get back on to the dealers as it's supplied in the box with the loom and the sockets..
    Jul 2006
    hartlepool
    cheers matey i will look in to this, cheers
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    If it is any use I had a witter towbar and single electrics fitted by one of their authorised engineers and the first time I used it - DEAD! Checked it all out with the lighting board on wife's car and it worked perfectly. Back on the VX - nothing.
    Finally worked out that there are 6 wires leading from the lighting board that are used and one (the white one I think) that isn't. If all 7 are not connected up then presumably tech 2 decides that there ain't anything there.....
    I'm not an electrician and I have paws instead of hands so please be gentle if you disagree with the above, though all constructive comments are welcome
    Jul 2006
    hartlepool
    cheers matey, any suggesting is appretiated, were stumped with the damn thing
  1. Help with Signum towbar
    By MARTIN FROM LLAN in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2012, 08:23
  2. towbar for a signum..?
    By signum driver in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2011, 16:00
  3. Signum Towbar
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2006, 10:26
