Glued it in now. Almost complete. Will be painting the last bits today.
Fantastic I would love this doing to mine but I'd end up with a broken Xbox if I attemted it
Thanks very much. Its not hard to take apart. Just go slowly and you should be fine. Just be prepared to loose your xbox for quite a few weeks
Almost finished the painting now too.
All done now and Arron loves it
Gorgeous, how did you get the lights to work and where did you find the materials also did you use a dremmel
Hi Mate
I used to solder the lights onto the power points on the motherboard but then I found this http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_343wt_1307
Makes life so much easier. He has other colours too.
You will also need an xbox 360 opening tool.
http://www.ebay.co.uk/itm/XBOX-360-U...#ht_228wt_1039
Defeniatley a Dremel for cutting and large straight and curved hand files from B&Q (3 in a pck) Thats if you just want to put a window or two into the case.
If like me you want to do a design then you will also need small hand files from B&Q (5 in a pack I think) for all the little small curves etc.
I have a spare xbox top lid and a sheet of perspex if you want them. Just ask for delivery costs to be covered. That way you can do most of your modding and still play the xbox
Let me know
Chris
