Thread: need help
    Regular Member selv1980's Avatar
    warwickshire
    Default need help
    i just got my cars wheel alignment done and front camber, the bloke said he adjusted the front and rear alignment, i asked about did he do the rear camber but he rekons you cant do it, but i said you could is he right or am i
    Regular Member dervdoc's Avatar
    Co.Armagh
    you are as the bolt in the back bottom arm has on offset lobe on it to adjust camber, need to get mine done as i lowered my motor and the back wheels lie in at the top, over time chawing the inner tyre surface off
    warwickshire
    ill ring them and see what he has to say for himself now, cheers matey
    Co.Armagh
    Quote Originally Posted by selv1980 View Post
    no problem deffinately get it sorted if the car has been lowered or ya could end up getting 2 rear tyres after a while
    warwickshire
    i just chatted to them i got to take it back monday, he rekoned there wasnt any bolt you could adjust, and the bloke said he dose it day in and day out, yeah right may be other cars but not these, has anyone got a pic of the ecentric bolt, i just wanna go with as much info as i can just to blow them out
    Co.Armagh
    sorry my camera aint working but if ya go to the rear of your veccy and ya'll see the 2 bottom suspension arms, its the bolt securing the arm to the chassis not the one at the hub, it just looks like a normal bolt and washer but if ya look at the washer the bolt head aint directly in the centre of the washer its offset therefore letting you adjust the camber
    spot on mate....
    if the fitter doesn't know that.. take it eleswhere....
    warwickshire
    thing is in my town there are only 2 garages that does camber adjusting and there both meant to be good the 1st one i went to knew exactly what to do but wanted £152, and the other my mate knew them and sorted it for me and was £52 so you can see what one i went to, i cant wait till monday and i hit the bloke with all this info he was so postitive that there wasnt a single bolt he could adjust ha ha,
    Nice one guys your a big help
    Point him in our direction if he needs a 'how-2' if he does it 'every day'..
