Thread: Various questions...
    Chelmsford
    Default Various questions...
    I've recently bought myself a 04 plate Veccy 1.8 hatchback (31k) and have noticed a couple of things which I'd like some advice on:
    1) rear suspension squeaks badly when going over speed bumps, often much worse after the cars been sitting still over night. Just general cold and dampness or something to worry about?
    2) A couple of times I've noticed a rattle when moving the clutch at standstill, like when pulling away slowly or crawling along in traffic. It's particularly bad if I deliberatly pull the clutch up the the bite rapidly and sounds like something's not tightened properly and is knocking about. Any ideas?
    3) I've had difficulty finding out the paint colour code so I can get a touch up kit (some ****** was driving down the hard shoulder of the M1 for no apparent reason and I got a stone to the front passenger door). The car is black but with a metallic sparkle. Halfords do a Vauxhall Black Sapphire Pearlescent kit and it appears to be the only one suitable. Anyone know if this is right?
    Any help would be very much appreciated.
    Black sapphire is the colour, it hs a couple of codes, 1 is 2hu ....other is 20r which seems to appear on newer cars ..
    Chelmsford
    Thanks, much appreciated.
    I had the rear shocks on my 2.2sri changed when it was 2 years old, under warraanty, they were creaking / banging over bumps as well ...
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by DNS View Post
    Paint code will be on the plate on the inside of the driver's side B pillar. Best bet is to get the Vx touch-up stick as it'll be a perfect match - and they're cheaper then the Halfords ones!
    try changing the antiroll bar mount rubbers to cure the 1st one....
    the pressure plate may be playing up.. clutch problems on 1800's are quite common..
    Regular Member dervdoc's Avatar
    Co.Armagh
    sounds like thrust bearing or release bearing maybe for no.2 but probably not as she only has 31k miles
    Quote Originally Posted by dervdoc View Post
    they've gone in less miles than that....
    oh, and the antiroll bar bushes are easy and cheap to change..but you'll never totally shut it up..there will always be a little squeak.
    Chelmsford
    I initially wondered about a bush problem but discarded the idea as it's intermittent. The dealer I bought it from MOT'd it for me and no problems came up.
    well it's only really ever a visual inspection on the bushes.. if they look badly worn then they'll get a bar out to test for play.. only trouble is the vectra makes a noise before the bushes look really bad..
  1. HID questions
    By Angel1368 in forum Styling
    Last Post: 9th May 2012, 11:08
  2. A few questions!
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2009, 21:38
  3. A few questions.......
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2007, 17:18
  4. Just a few questions ;)
    By BlueRob in forum Petrol Engine related
    Last Post: 24th July 2007, 04:30
  5. Questions !!!
    By zubs187 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 17:16
