Results 1 to 3 of 3
Thread: stalling on slow down
    Apr 2006
    Quinton
    Default stalling on slow down
    Hi,
    I apologise in advance for asking a question about a non vec c........... (at the moment touch wood my cdti is doing fine )
    however my run around..... an astra 1.6 8v active has developed a bit of a prob I wondered if anyone had experienced or could give thoughts on.
    Its 3 yrs old and done 50k.
    Driving home last night on the approach top a round about, I dropped the clutch in to slow down and the car stalled. It took a while to restart it again.
    Then about four/five times on the way home if i pushed the clutch in the revs would fall, and fall, and fall then stall.
    it did this several times on the way home, intermittantly.
    It seemed ok this morn for 60+ miles but as i got near work it did it a further 3 times
    any ideas
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    not sure bout the 1.6 engine m8 but had this problem on a couple of vec b's in the past dip clutch engine would stall but it did start straight away. It was the idle valve. Just took it out & cleaned it out with carb cleaner. That done the trick on both of them. I'm sure i will be correted if i'm wrong, just a thought m8
    Dec 2005
    In the sponge-monkey tent
    100% Idle Control Valve cleaning needed. Exactly the same symtoms on the Snot Rocket. Remove the air intake pipe from the throttle inlet, take the ICV off and give it a good clean with carb spray and an old toothbrush. While you're at it, clean the throttle butterfly and crank case breather.
  1. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  2. Car stalling
    By rob123 in forum Diesel Engine related
    Last Post: 29th January 2010, 20:25
  3. stalling in neutral
    By woodylove101 in forum Engine & Drivetrain
    Last Post: 30th June 2008, 19:55
  4. Our Vectra's Stalling
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2007, 17:31
  5. Stalling
    By MrBond in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2007, 12:50
vectra 2005 stall dipping the clutch
