Thread: Fog light bulbs
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Fog light bulbs
    Just a quickie, what type of bulbs do the fog lights use?
    member of the smoke patrol 230bhp+
    i think its a h3
    i maybe wrong i couldnt bet my life on it
    Jul 2006
    Northampton
    Trim : Sri
    Thanks, i was just looking at getting tinted fog lights, like the blue ones for headlights
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Be Careful matey, i upgraded mine to a higher wattage and the heat cracked the lense!
    Gutted.
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Woodsta View Post
    Gutted.
    No im aware of that and (i dont know about fog lights but) on headlights higher wattage can fail mot
    Quote Originally Posted by Mugualigwian View Post
    the max wattage of a driving lamp is not to be more than 55 watts"dipped and fog" there are no limits on your main beam
    and the eu making on the bulb are for the shape of it ,,that why companys tell you off road use only
    a higher wattage bulb will need more power to run it if the wire isnt up to the job its going to cost you
    a fuse it to protect the wire not whats on it ""ie the bulb""
    but the way a 55 watt bulb can pull 7.779 amps when its first switched on
    a 100 watt bulb cam pull 14 amps when you switch it on
    be carfull with upgrading bulbs if you up the wattage you will need a relay to keep things safe
    Feb 2006
    Guttedsville
    They are H3's mate.
    Jul 2006
    Northampton
    Trim : Sri
    Cool thanks guys. im not looking at upping the wattage just simply getting a blueish tint.
  1. Fog light Bulbs
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 16:48
  2. fog light bulbs
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 22:38
  3. Fog Light Bulbs.....
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2009, 14:16
  4. fog light bulbs
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2008, 18:12
  5. sri fog light bulbs
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2008, 18:26
