Results 1 to 10 of 17
Thread: have i been done
    Mar 2007
    northwest
    Default have i been done
    took my car to a garage because it was stalling when it got warmed up and the engine warning light came on the dash i have a vectra s reg 18i patrol this is wot he did if it maks any sens
    cambelt kit £88 £15vat
    camshaft sensor kit £40 £7
    crank sensor £31 £5
    rocker cover gasket £20 £3
    diagnostic test £45 £7
    garage laber rate £122 £21 total £408
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Idle valve - Known for it
    Full Member Big Sig's Avatar
    Why would he charge you for a cambelt kit if all it was doing was looking at it stalling??????? Could also be the inlet manifold needs cleaning, just past the butterfly valve.....
    Dec 2005
    In the sponge-monkey tent
    Did he clean the Idle Control Valve (ICV)? If not and it still stalls then yes, you've been had. Dirty ICV is pretty common and takes about 20 minutes and a can of carb cleaning spray to fix.
    Nicking Ya Dinner.
    On the other hand, you could look at it that you now have all the bits that do fail replaced, a new belt is never a bad thing anyway, if that lot had been done in a Vx dealer you could easily double it.
    Did it sort out your problem?
    If not, do get the ICV cleaned, and the EGR valve as well, and the other two things that could cause it are the Exhaust probe and the Airflow meter.
    Mar 2007
    northwest
    been out in it two night yes its still stalling thank to all am taking all in night mare
    Chelmsford
    if the car was at or approaching 60k then the cambelt is a good thing to get anyway. I agree about the ICV, I cleaned mine several times over the 5 years I had your model car, always idled faultlessly afterwards.
    Regular Member kgsric's Avatar
    Northants
    Quote Originally Posted by DNS View Post
    is 60k the reccomended miles 2get it changed?
    on the 1800, i'd change the belt every 40,000..they have a nasty habit of going 'boing' if you run them much longer..
    Mar 2007
    northwest
    were would i find this icv and is it easy to clean is it a job i could do my self
