Results 1 to 3 of 3
Thread: steering wheel change
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    Default steering wheel change
    can anybody tell me how to change the steering wheel of an 06 vectra?
    do you just disconnect the battery remove the airbag then remove the wheel?
    do you have to get the airbag warning light reset using tech 2?
    on the understanding that what you are about to do is VERY dangerous and should only be attempted if you are fully aware of the consequenses..
    remove the battery leads..leave the car like this for 1/2 hr.. this will let the airbag firing capacitors power down..
    undo the screws in the back of the steering wheel that hold the module on and disconnect the wiring as you withdraw the module....now put it somewhere safe and treat it as an 'unexploded bomb' as thats what it is...
    now you can remove the wheel's securing nut and change..
    replacement is the reverse..and you won't need to get the airbag light reset unless there is a problem with any of the connections ( unlikely)..
    Feb 2007
    crosshouse
    Thanks Very Much For The Info
    I Was Concerned About Disconnecting The Airbag As Ive Heard Of The Being Ativated And Going Off Like A Bomb
  1. Steering wheel change help
    By drmak1992 in forum Bodywork & Interior
    Last Post: 28th December 2012, 22:21
  2. Steering wheel change
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2012, 22:44
  3. steering wheel change
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 13:49
  4. LED change in steering wheel.
    By connery-sri in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 22:17
  5. change griffin on steering wheel???
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2009, 19:31
