Thread: brakes?
    Regular Member LAV6Y's Avatar
    Oct 2006
    Lisburn, NI
    Default brakes?
    I know that there is a sensor in the front brakes on the veccy but is there sensors on the back pads too. Mine look pretty low and there is no sign of the warning light coming on?
    Also could i change the pads myself? If not, how much would it cost for vx to do them?
    Cheers dudes.
    Feb 2006
    Guttedsville
    There's a sensor on the front, but not on the rear, you'll need to listen for scraping noises. The backs can be awkward as the caliper piston needs to be wound back. If in doubt, get a garage to do it. At the end of the day, you don't want to be bodging brakes!!
    member of the smoke patrol 230bhp+
    you need this tool to wind the brakes back
    http://cgi.ebay.co.uk/DRAPER-33606-C...QQcmdZViewItem
    http://cgi.ebay.co.uk/SYKES-PICKAVAN...QQcmdZViewItem
    its not had to do the job bet you do need the tool to do it
    Oct 2006
    Lisburn, NI
    your right, i need the tool !!!
    However, if i though i would be paying £50 or £60 quid for vx to change them it would be worth my while in buying the tool and pads and just doing it myself,
    WOULDN'T IT ?????
    [Ex]Admin Duncan's Avatar
    It's an easy enough job Larry - and as you say the tool would cost you as much (or less probably) as the labour for the dealer to do them. There is a How 2 on how to change rear pads. Have a look and see if it helps.
    It is an easy job, but as Andrew said if you're not confident doing it then get it done by somebody else.
    duncan is right, with the tool i bet you could do both side in about 1 1/2 hours
    and thats taking your time to
    1.5 hours? How many tea breaks are you taking?
    took me less than 30 mins to do mine but then i did have all the tools for the job
    and i had a cupper to
    its not a race to finish the job you just need to do it right
    lol - I know. I was jesting with you.
    It always takes longer the first time you do something anyway, so by the time you've got it jacked up, wheels off, sussed out what you're taking off etc. an hour and half is probably about right for doing it for the very first time from start to finish.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Quote Originally Posted by chrisgettings View Post
    Be careful as i don't think either of these will fit the piston - will need to get a seperate adaptor
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
