Results 1 to 10 of 21
Thread: Turbo heat up and cool down
    Bonnie Scotland
    Default Turbo heat up and cool down
    Guys
    Having run a Nissan 200SX a couple of years ago, I was always adviced to let the turbo cool down after having a good blast in it so as to let the turbo bearings cool down. Now I've got a 3.0V6 CDTi, do I still need to let the turbo cool down??
    ohrid
    dont turn it off as soon as you park the car. wait for 30 seconds.
    Yep, as above and same for the 3.0V6 I'd think. After a good blast I give mine (2.0T) 'cooling down' drive of a few minutes to let the turbo cool down. Manual says 30 seconds but I'd rather give it longer after I've gone out for a real good blast.
    Worst thing, as you probably are aware, is to go for a blast and pull up and turn engine straight off. Doing that repeatedly will shorten the turbo's life.
    Jul 2006
    That would be why the turbo on my work astra had to be replaced at 15 months old then?....
    Regular Member surreyl31's Avatar
    Feb 2007
    somerset
    i would leave it upto two mins to carm down after a good run
    Regular Member breezephil's Avatar
    LONDON
    Nice minute or two at idle is the best I think, the turbo isnt doing any work then and its still getting Oil Pumped to it, when you just turn the engine off the Blades of the Turbo are still spinning, but now they will get Hot and expand, causing problems with the bearings as far as I am aware.
    lowestoft
    The need for a cool down period on petrol turbos is to prevent oil carbonising on the bearings, as Diesel turbos run at a lower tempture the cool down period is not needed as much. Thats why variable vane turbos are common on diesels but not on petrols because they are built with lower tempture tollerence materials (except the new 911 turbo but thats quite expensive). I drive a Fiat coupe 20v and have seen the turbo glow red after a run, you dont get that on a diesel.
    Regular Member wardy's Avatar
    Chichester
    My wife had a Nissan Mistral (Jap import Terrano) 2.7 TD. That had a turbo timer fitted which meant you could switch off the ignition, but the engine would still run until the turbo had cooled.
    Caused a few stairs at the pumps!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    I have a turbo timer (its not fitted yet as im lazy lol) only cost me a few quid from ebay, worth a look
    Here, there and every where!
    mmmmmm...........wonder how easy THIS would be to fit or would CANBUS throw a fit
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. Easiest way to remove turbo heat shield?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 29th October 2012, 20:01
  3. Polished my turbo heat shield
    By Kev_A in forum Styling
    Last Post: 27th March 2012, 00:06
  4. Another turbo heat shield rebuilt
    By bobssignum in forum Detailing and Car Care Discussion
    Last Post: 14th April 2011, 18:37
