Results 1 to 3 of 3
Thread: PAS Fluid level
    Regular Member Rob_the_Scot's Avatar
    London
    Default PAS Fluid level
    Hi guys, whilst coming over Shap on Monday, the PAS warning light came on, stopped the car and it went out. Driving down to London it came on and wenty off intermittantly. Called the garage to get her booked in for a check over, thay asked if I had checked the fluid level.
    This is the part where I own up to be a complete idiot ...I have no idea where to check this, any help would be much appreciated
    Thanks in advance
    it's under the driverside front headlamp.. easier to get to if you remove the front bumper..you could also then check the connections of the electrical plugs as they are know to give problems..the levels are marked on the outside of the 'bottle'..
    if it's intermittant, then i'd say that it's a dodgy connection rather than anything sisnister.. no signs of leaking PAS fluid is there?
    London
    Cheers, will check in the morning, when I can get the bumper off.
    No sign of any leakage
    Thanks for your help
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. How to check Power Steering Fluid level?!?!
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th January 2014, 19:14
  3. how to disable low washer fluid level
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2012, 13:54
  4. clutch fluid level? how do i check it?
    By renton608 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 19:25
