Results 1 to 10 of 17
Thread: Recent Pad Change
    Regular Member Perry's Avatar
    Watford Herts
    Default Recent Pad Change
    About a month ago I had the pads changed by a local tyre place we use at work, they also supply and fit brakes. Anyway since having them fitted I am sure I get a very slight knock noise when coming to a stop, and they other bit is I feel the pedal is still a bit spongy and if I pump it it feels right but if I keep my foot pressed on the pedal then it slowly goes to the bottom, does this happen on anybody else's or does it seem like there may be an air leak??
    I know it's not explained in the best terms
    if the engine is off, does the pedal pump up firm or not...???
    Watford Herts
    Ermmmmmmmmmm pass will go try it in a bit.
    member of the smoke patrol 230bhp+
    omg not again been here befor
    id start will bleeding them
    morton
    changed rear pads on mine last weekend and had to bleed the rear brakes ! never had too before ! but it cured mine ! hope it helps ??
    Quote Originally Posted by Perry View Post
    let me know as it depends on what i tell you next..
    cant put the back ones upside down. i know they dont fit i just looked
    Watford Herts
    Thanks, totally forgot to do it before leaving work until now, will do it first thing in the morning.
    Thanks again
    Watford Herts
    Ignition off and pedal gets very stiff and does not go down.
    That's fine then. Pedal 'sinking' when engine is running is normal.
    Knocking, not sure. I'm sure Mark will have some suggestions.
    Which pads BTW? - front or back?
  1. Some recent pics for yas
    By tditony in forum Quick Photo Album
    Last Post: 28th July 2011, 18:09
  2. Replies: 18
    Last Post: 5th July 2010, 23:36
  3. Recent changes in MEN
    By vauxie in forum General Chat
    Last Post: 21st August 2009, 17:18
  4. recent mod, thats it for now!!
    By discco in forum Styling
    Last Post: 17th March 2009, 15:49
